Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 14389
Total: 100534329
Forums › The Car › 206 Problems › Comms Unit
Comms Unit
lana
PostPosted: Wed Apr 06, 2011 3:39 pm Up
Looking for a bit of advice.
Had a reconditioned unit fitted,however the car will not start with reconditioned comms unit fitted.
I sent chassis number and reg to supplier to ensure i purchased correct part.
When the old comms unit refitted it starts fist time.
When i had it fitted i gave garage spare key not fob key could this make any difference?,
Any help would be appreciated.
PostPosted: Wed Apr 06, 2011 3:50 pm Up
The COM shouldn't effect the car starting Confused
lana
PostPosted: Wed Apr 06, 2011 3:55 pm Up
That's what i thought, however i will not start.
Have been advised to have the key recoded but don't know if that would make a difference.
skard
PostPosted: Wed Apr 06, 2011 3:59 pm Up
i don't think the comm unit in the 206 has any links to the immobiliser system.
perhaps the recon unit has a short in the wiring?
lana
PostPosted: Wed Apr 06, 2011 4:08 pm Up
Pre 2001 don't.
The comm unit on models after that control wipers,lights,immobiliser and anything else they could attach i think.
PostPosted: Wed Apr 06, 2011 4:10 pm Up
Immobilser is in the BSI and the ring is around the ignition barrel
Do you have esp?
lana
PostPosted: Wed Apr 06, 2011 4:14 pm Up
No Does not have esp the car is 03 reg 1.4lx.
PostPosted: Wed Apr 06, 2011 4:36 pm Up
Yeah I gunna go with Skard and say the recon one is dodgey because the Com's are interchangable and nothing to do with the immobilser or starting the car.
Dodgey com sending wrong signals to the BSI, will put it into some sort of protective mode and cause problems.
lana
PostPosted: Wed Apr 06, 2011 4:44 pm Up
Thanks do you know how i can get the comms unit tested?
lana
PostPosted: Wed Apr 06, 2011 4:50 pm Up
Do you know what part number is for comms unit 6242E9 please.
PostPosted: Wed Apr 06, 2011 4:54 pm Up
DELPHI
- MULTIPLEXING ASSEMBLY AND FRONT WIPER BLADE WITH RAIN SENSOR AND REAR SCREEN WIPER AND NO COMPUTER AND FRONT FOG LIGHTS AND WITHOUT ELECTRONIC STABILITY PROGRAM AND AUTOMATIC HEADLAMP ILLUMINATION
lana
PostPosted: Wed Apr 06, 2011 4:58 pm Up
That sounds like the right one.
On the recon unit it had a sticker on the back about 10 numbers and letters, i just wanted to make sure they had provided me with unit 6242E9.
