Online Now [416]:
Visitors: 415
Today: 103226
Total: 155973211
Forums › The Car › 206 Problems › GTI wont start.
GTI wont start.
Go to page Previous  1, 2
PostPosted: Wed Apr 06, 2011 4:40 pm Up
How do you cure the immobilizer?
punk
PostPosted: Fri Apr 08, 2011 6:44 pm Up
If it is the immobiliser shouldn't the display read immobiliser fault
PostPosted: Fri Apr 08, 2011 6:49 pm Up
The display's a bit dodgey and doesnt work.
AX-Rated
PostPosted: Sat Apr 09, 2011 3:19 am Up
My guess is that 2 pin connector goes to the crankshaft sensor.
If the ECU doesn't see this signal, it wont send thee firing signals to the Spark plugs or the injectors.
The sensor is close to the oil filter and sometimes wont give out fault codes if its defective/not plugged in.
Black 03 GTi
PostPosted: Sat Apr 09, 2011 7:06 am Up
Would this stop the fuel pump from priming as well?
leigh_boy
PostPosted: Sat Apr 09, 2011 1:47 pm Up
if the fuel pump is not priming there is a relay that controlls lots of different things big black 1 under the ecu its about £40 for pug or u could get 1 from a breakers and will probabbly fix the fault.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Sat Apr 09, 2011 2:40 pm Up
The big relay is about £15.
PostPosted: Sun Apr 10, 2011 12:48 pm Up
Does the big relay control the digital heater control as well?
leigh_boy
PostPosted: Mon Apr 11, 2011 12:41 am Up
really??
i bought 1 about 2 years ago now becuae mine packed up and im sure i paid about 35 / 40 from pug, then again might be talking about something different.
*DEAD*206 Gti 138
AX-Rated
PostPosted: Mon Apr 11, 2011 1:37 am Up
The heaters only blow when the engine is running, but they cam be adjusted without the engine running.
The crankshaft sensor wouldn't affect fuel pump priming.
Black 03 GTi
PostPosted: Mon Apr 11, 2011 5:20 am Up
I know they only run with the engine running, I mean the whole control unit has gone dead so you cant adjust it. Im asking if its that big relay that controls that as well?
206gt160
PostPosted: Mon Dec 08, 2014 8:24 am Up
Did you get to the bottom of this problem?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Page 2 of 2
