Online Now [1010]:
Visitors: 1010
Today: 234543
Total: 151079294
Forums › The Car › 206 Problems › Help/Advice Needed
Help/Advice Needed
Matt
PostPosted: Fri Apr 08, 2011 12:06 pm Up
Trade Rating: +32
I have a problem. I started getting a strange noise this afternoon on my way home from work. It sounds like when you put those things on your spokes when you were a kid.
Any ideas?
It does it in neutral/coasting and goes when I put the gas down. It also appears to get louder and quicker the faster I go.
Any help appreciated.
Thanks Matt.
PostPosted: Fri Apr 08, 2011 12:08 pm Up
I had exact same thing, was gearbox in my case. I Did have a vid will see if I still have it.
j3xoc
PostPosted: Fri Apr 08, 2011 12:13 pm Up
lol i remember those i had those on my push bike and they hit the spokes as you went round lol good days good days yer could be the gearbox if it does it in neutral but also could be anything it loud loud noise or just small loud could be s**t in your wheels just a guess mind you Very Happy
Matt
PostPosted: Fri Apr 08, 2011 1:05 pm Up
Trade Rating: +32
Thanks Ben.
Yea it's very loud.
Have the radio on atleast 20 now lol.
move_2001
PostPosted: Fri Apr 08, 2011 1:57 pm Up
Could be coil pack on way out
only travel as fast as you angel can fly
j3xoc
PostPosted: Fri Apr 08, 2011 2:42 pm Up
duno my coil pack has gone before and i just lost like engine response and was only firing on 3 but no loud noise
do u know exactly where the noise is coming from?
PostPosted: Fri Apr 08, 2011 3:11 pm Up
I can't find the vid i had must have deleted it,
Mine did noise just like yours and my case like said above was to do with gearbox, I was told it was diff side of the box at fault, but i changed full box.
I jacked up front end of car put it on stands, got under it while mate in a sense drove it by putting it in gear etc that's how I found out just were the noise was Comming from,
Matt
PostPosted: Fri Apr 08, 2011 3:25 pm Up
Trade Rating: +32
Yea it similar to a noise I had last year. I changed the box then, only for a 2nd hand one from a scrappy though.
So it would appear that one has failed aswell, in less than a year too.
Mechanic said it's a common fault and that the 206 gearbox is pretty s**t.
Unsure wether to get another 2nd hand one or get mine recon'd.
