Latest: dreyfalon
Overall: 17121
Online Now [324]:
Visitors: 323
Today: 89388
Total: 97389385
Forums › The Car › 206 Problems › Changing a headlight ajuster?
Rob2859
PostPosted: Fri Apr 08, 2011 5:25 pm Up
I am assuming this is broken and its why only one light can be manually adjusted.
Anyway how do I get it off? Is it a force it with a screwdriver affair?
Also its the passenger side one. Can I replace it without taking the headlight out? Very Happy
DeadEyePaul
PostPosted: Sat Apr 09, 2011 12:42 am Up
Put a allen key in the CIRCLED bit, twist it until the arm extends ARROWED
grab the unit twist it 90 degress then lightly pull towards you. You can see it is inside a track/runner you have to try and slide it off the track/runner
Rob2859
PostPosted: Mon Apr 11, 2011 5:38 am Up
ah I see. Thanks for your help Very Happy
PostPosted: Mon Apr 11, 2011 5:52 am Up
Removing the dipped beam bulb & holding the reflector with a finger to stop it moving helps on refitting Wink
