Latest: DanDan17
Overall: 17128
Online Now [162]:
Visitors: 161
Today: 2291
Total: 100477129
Forums › The Car › 206 Problems › ECU,BSI, and keys and barrel ring...... Need assitance :(
punk
PostPosted: Sat Apr 09, 2011 5:33 am Up
You sir, are a king,
But what I meant to say if this was not to work, and I needed to replace ecu, bsi ect, then I would require you help if i was to find anything on ebay to ensure it was the right one, Which I hope you don't mind doing,
Iv been looking around a few other forums, and this seems to be a recurring fault, which people always suggest first trying to change the Aerial.
I really wish i joined this forum 4 months and £700 ago.
PostPosted: Sat Apr 09, 2011 1:09 pm Up
ahh yeah, no worries, just get in touch
punk
PostPosted: Sun Apr 10, 2011 11:23 am Up
Cheers bud, Is there anywhere I can buy the Transponder Aerial online? or just the Dealer?
PostPosted: Sun Apr 10, 2011 11:25 am Up
Any Peugeot / Citroen main dealer parts dept will happily sell you one pretty cheaply.
punk
PostPosted: Mon Apr 11, 2011 4:26 am Up
Ok, well I went to Peugeot this morning and picked up the transponder Aerial, I fitted it and same problem. Sad
So I guess the only option is a BSI ECU replacement
PostPosted: Mon Apr 11, 2011 4:29 am Up
Turn the ignition OFF but leave the key in, now open the drivers door, do you hear the key in igntion warning beep?
punk
PostPosted: Mon Apr 11, 2011 4:33 am Up
Just tried that, and yes i do hear three quick beeps
PostPosted: Mon Apr 11, 2011 4:36 am Up
That means the aerial is seeing the transponder chip inside the key.
What year of 206 is this?
punk
PostPosted: Mon Apr 11, 2011 4:37 am Up
2003 2.0 GTI I believe
punk
PostPosted: Mon Apr 11, 2011 4:38 am Up
2.0 206cc gti 2003
PostPosted: Mon Apr 11, 2011 4:39 am Up
Can you borrow an EOBD code reader from a friend / mechanic?
Plug it in & see if it will communicate with the engine ecu.
16 pin EOBD diagnostic socket is behind flap to drivers right knee, turn platic screw with a coin & lift up / unclip the flap.
punk
PostPosted: Mon Apr 11, 2011 4:41 am Up
I had a diagnostic done not long back, I had some old faults cleared. Mechanic plugged it into the fuse area by my lower right knee.
PostPosted: Mon Apr 11, 2011 4:45 am Up
If the engine ecu is immobilised you WONT be able to communicate with it Wink
It really needs scanning with Peugeot Planet.
BBA reman can repair BSI & engine ecu's
www.bba-reman.com/uk/index.aspx
punk
PostPosted: Mon Apr 11, 2011 4:50 am Up
I do not want to spend too much more money. How much do they charge, im having trouble finding a price list On the website!
PostPosted: Mon Apr 11, 2011 4:55 am Up
They offer so many different repair services on virtaully any make of car depending on actual problems that a price list would be pretty huge.
Best thing to do would be to speak to them over the phone Wink
A scan with Peugeot Planet would help pinpoint the fault as well.
Page 3 of 7
