Posted: Sat Apr 09, 2011 5:33 am |
You sir, are a king,
But what I meant to say if this was not to work, and I needed to replace ecu, bsi ect, then I would require you help if i was to find anything on ebay to ensure it was the right one, Which I hope you don't mind doing,
Iv been looking around a few other forums, and this seems to be a recurring fault, which people always suggest first trying to change the Aerial.
I really wish i joined this forum 4 months and £700 ago.
Posted: Sat Apr 09, 2011 1:09 pm |
ahh yeah, no worries, just get in touch
Posted: Sun Apr 10, 2011 11:23 am |
Cheers bud, Is there anywhere I can buy the Transponder Aerial online? or just the Dealer?
Posted: Sun Apr 10, 2011 11:25 am |
punk wrote: |
Cheers bud, Is there anywhere I can buy the Transponder Aerial online? or just the Dealer? |
Any Peugeot / Citroen main dealer parts dept will happily sell you one pretty cheaply.
Posted: Mon Apr 11, 2011 4:26 am |
Ok, well I went to Peugeot this morning and picked up the transponder Aerial, I fitted it and same problem.
So I guess the only option is a BSI ECU replacement
Posted: Mon Apr 11, 2011 4:29 am |
Turn the ignition OFF but leave the key in, now open the drivers door, do you hear the key in igntion warning beep?
Posted: Mon Apr 11, 2011 4:33 am |
Just tried that, and yes i do hear three quick beeps
Posted: Mon Apr 11, 2011 4:36 am |
punk wrote: |
Just tried that, and yes i do hear three quick beeps |
That means the aerial is seeing the transponder chip inside the key.
What year of 206 is this?
Posted: Mon Apr 11, 2011 4:37 am |
2003 2.0 GTI I believe
Posted: Mon Apr 11, 2011 4:38 am |
2.0 206cc gti 2003
Posted: Mon Apr 11, 2011 4:39 am |
punk wrote: |
2003 2.0 GTI I believe |
Can you borrow an EOBD code reader from a friend / mechanic?
Plug it in & see if it will communicate with the engine ecu.
16 pin EOBD diagnostic socket is behind flap to drivers right knee, turn platic screw with a coin & lift up / unclip the flap.
Posted: Mon Apr 11, 2011 4:41 am |
I had a diagnostic done not long back, I had some old faults cleared. Mechanic plugged it into the fuse area by my lower right knee.
Posted: Mon Apr 11, 2011 4:45 am |
punk wrote: |
I had a diagnostic done not long back, I had some old faults cleared. Mechanic plugged it into the fuse area by my lower right knee. |
If the engine ecu is immobilised you WONT be able to communicate with it
It really needs scanning with Peugeot Planet.
BBA reman can repair BSI & engine ecu's
www.bba-reman.com/uk/index.aspx
Posted: Mon Apr 11, 2011 4:50 am |
I do not want to spend too much more money. How much do they charge, im having trouble finding a price list On the website!
Posted: Mon Apr 11, 2011 4:55 am |
punk wrote: |
I do not want to spend too much more money. How much do they charge, im having trouble finding a price list On the website! |
They offer so many different repair services on virtaully any make of car depending on actual problems that a price list would be pretty huge.
Best thing to do would be to speak to them over the phone
A scan with Peugeot Planet would help pinpoint the fault as well.
