Online Now [591]:
Visitors: 590
Today: 111298
Total: 105688203
Forums › The Car › 206 Talk › Bonding very soft rubber to metal and plastic?
Rob2859
PostPosted: Mon Apr 11, 2011 5:36 am Up
How can I do this? Its a soft rubber strip almost foam like. Too soft for self tappers. Need to be weatherproof and removeable without damage to paint.
Is there a particular type of double sided that could be used?
DeadEyePaul
PostPosted: Mon Apr 11, 2011 8:00 am Up
Tigerseal it's an adhesive strong enough to hold spoilers to the car without drilling
Comes in a bathroom sealant type tube
PostPosted: Mon Apr 11, 2011 8:03 am Up
Tigerseal isn't removable without damage.. Wink
Velcro?
Whats it for?
DeadEyePaul
PostPosted: Mon Apr 11, 2011 8:05 am Up
Velcro?
Whats it for?
Didn't see the removable part, sorry lol
Rob2859
PostPosted: Mon Apr 11, 2011 9:10 am Up
Its for exterior trim. bottom of the sills and other places. More info if its a success. Just an experiment.
What is the sticky stuff they use for vinyl wrap and stripes? something like that in a double sided form maybe. I don't think a glue will do it without destroying the paint.
Danw_VVT
PostPosted: Mon Apr 11, 2011 9:12 am Up
3m double sided tape?
edit:
solutions.3m.co.uk/wps...SidedTape/
Rob2859
PostPosted: Mon Apr 11, 2011 9:15 am Up
I can see that being hard to remove. Wont it take the laquer off too?
Danw_VVT
PostPosted: Mon Apr 11, 2011 9:19 am Up
generally lacquer is fine with adhesive if its not fresh. putting it on old lacquer should be ok and its easy to get off with a heat gun/ hairdryer and a bit of AG intesive tar remover.
use it in the training school my dad works at. ( they teach panel beating and spraying )
EDIT:
iirc this is the actual one
www.apetape.co.uk/gbu0...-9098.html
PostPosted: Mon Apr 11, 2011 9:55 am Up
cgi.ebay.co.uk/DOUBLE-...27b19ef070
i use this to attach the rollbar padding onto the rollcage. (ie. foam to powder coated metal)
Rob2859
PostPosted: Mon Apr 11, 2011 10:25 am Up
might go with that dan. As long as it doesn't harm the paint it should do the job
