Online Now [380]:
Visitors: 379
Today: 65908
Total: 156781219
Forums › The Car › 206 Problems › Spare Key stuck In Ignition..
Go to page Previous  1, 2
SDK206
PostPosted: Mon Apr 11, 2011 12:35 pm Up
are you able to remove the lower steering wheel cowling?
i so you should be able to get at the barrel to release the key
If in doubt, drop a cog and put your foot down Smile
PostPosted: Mon Apr 11, 2011 1:30 pm Up
Does the key start the car? Are you able to start it?
gpvecchi
PostPosted: Mon Apr 11, 2011 1:35 pm Up
If your car is a pre-mux, that's a known problem: it's the electric part of ignition that is fused... Try rotating key with strongness: it can break inside ignition, but that's the only way to remove it. If you can remove it, you can buy just electric part of ignition (P/N 992712), elsewhere you'll need new complete ignition with a new key...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Mon Apr 11, 2011 3:58 pm Up
ONLY if you can turn the key to the barrel service position Wink
SDK206
PostPosted: Tue Apr 12, 2011 2:26 pm Up
yes i missed that bit mate cheers Smile
i was under the impression that it did turn just wouldnt release when at position 0, should of said first time eh!
Page 2 of 2
