Latest: DanDan17
Overall: 17128
Online Now [142]:
Visitors: 141
Today: 38331
Total: 100558221
Forums › The Car › 206 Talk › curious, can 1.4 tiptronic gearbox straight swap into 1.6
heyziq
PostPosted: Mon Apr 11, 2011 3:13 pm Up
curious, can 1.4 tiptronic gearbox straight swap into 1.6 which is normal auto,no manual..
heyziq.com
heyziq
PostPosted: Mon Apr 11, 2011 3:25 pm Up
bump
heyziq.com
PostPosted: Mon Apr 11, 2011 3:29 pm Up
Yes
Whether it will work is another matter
TU engines at a guess?
PostPosted: Mon Apr 11, 2011 3:35 pm Up
you bump a post after 12 mins?
PostPosted: Mon Apr 11, 2011 3:50 pm Up
Possible, why anyone would want to is another matter.
There both bloody awful gearboxes & both are best avoided at all costs!
heyziq
PostPosted: Tue Apr 12, 2011 2:06 am Up
heyziq.com
hobnob48
PostPosted: Tue Apr 12, 2011 2:57 am Up
If the box is anything like a Vauxhall one then yes it should work. With Vauxhall its all the same but instead of having a gear linkage two motors fit in the hole to make it select gears and the clutch was the same just had some crazy pump. As for fitting an easytronic system don't even bother! The whole system uses so many sensors and if they do not get the right readings it will play up.
I learnt all of this after throwing £2k at a Easytronic Astra
edit: Actually Pug easytronic is different in how it works i think
heyziq
PostPosted: Tue Apr 12, 2011 9:42 am Up
hmm i cant get why you are trying to tell me/
heyziq.com
hobnob48
PostPosted: Tue Apr 12, 2011 12:03 pm Up
If you want to turn your car tiptronic it will be expensive. I believe thtthe pug tiptronic system is differnt to vauxhall. So ignore my last post.
Box will fit but it will need more than just the gearlinkage and clutch changing.
Just get a manual box and it will be easy
heyziq
PostPosted: Tue Apr 12, 2011 12:56 pm Up
Actually my friends want to sell his 1.6 complete engine+gb_bsi etc, and i have the 1.4 8v with multiplex, but thinking having tiptronic function is better because of traffic jam in city..thats why im planning swapping 1.6 but maintain my original gb inside
heyziq.com
PostPosted: Tue Apr 12, 2011 5:05 pm Up
With a 206 a manual gearbox & a clutch pedal is the smart way forward Wink
206 auto, not the best long term ownership prospect Wink
