Latest: DanDan17
Overall: 17128
Online Now [65]:
Visitors: 64
Today: 3709
Total: 100478547
Forums › The Car › 206 Problems › ECU,BSI, and keys and barrel ring...... Need assitance :(
PostPosted: Mon Apr 11, 2011 3:56 pm Up
Yeah would have been an idea to tell us that Laughing
Might have a few cracked wires, from the fuse box to the cabin loom
punk
PostPosted: Tue Apr 12, 2011 12:14 pm Up
Yeah maybe i should have mentioned that,I am ever so sorry, I took off the ECU today, and tidied up all the wires, checked for any that were cracked or frayed couldn't really find any issues. Then reattached it all. I checked the fuel and if it was coming through to the engine by disconnecting the fuel line from the engine ( in the engine bay, the small clip on bit) and the strangest thing happened. Firstly fuel shot through when the ignition was on, then on the second attempt nothing. So I re attached everything. I then took the keys out and locked up, went inside. Came out an hour later sat in the car and i could hear a small whirring sound coming from behind me ( with no keys in the ignition). Assuming this would be the fuel pump engaging, i disconnected the fuel line in the engine bay again, and fuel shot through. Yet when i go to start the car nothing. I always thought if there was an immobiiser in the car it would shut of the fuel?
punk
PostPosted: Tue Apr 12, 2011 12:15 pm Up
Must add before you all shout at me again. I as mentioned before am not very good with electrics, and i checked the wires around the ECU, I wasn't sure where else i needed to check...
PostPosted: Tue Apr 12, 2011 5:03 pm Up
Where abouts was the car damaged in the accident?
punk
PostPosted: Wed Apr 13, 2011 3:00 am Up
From what i am aware rear quarter panel, drivers side.
PostPosted: Wed Apr 13, 2011 3:32 am Up
Have a good check of the wiring around there as the fuel pump is in that general area.
punk
PostPosted: Thu Apr 14, 2011 5:58 am Up
Ok, so as much as I hate to admit it, I'm.calling myself defeated, I gave the the car to a local garage, see if they can find the fault......
Anjeve
PostPosted: Mon Apr 18, 2011 9:35 am Up
Any Progress at the garage?
Anjeve
punk
PostPosted: Mon Apr 18, 2011 2:28 pm Up
They are changing the fuel pump with a known working one, but I won't know till mud week
punk
PostPosted: Thu Apr 21, 2011 3:57 am Up
Got a call from the mechanic, he told me that he changed the ECU and the car is having the same problem.... Im somewhat sceptical if the work has even been done, are there any tell tale signs i can llook out for? Like would the millage change on the speedo?
Danny.
PostPosted: Thu Apr 21, 2011 4:36 am Up
IIRC the mileage would stay the same because it is stored in the speedo cluster... Unless thats just Pre-plexed...
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Thu Apr 21, 2011 4:39 am Up
The mileage is stored in the bsi and as yours is plexxed would only increased if the speedo was changed for one with higher mileage then that will overite the bsi.
punk
PostPosted: Thu Apr 21, 2011 4:55 am Up
Im surre mine is multi plexed... its 03
LilLew
PostPosted: Thu Apr 21, 2011 5:02 am Up
if they have done the work and replaced parts tell them u want the one that have came out of your car
2003 Pug 206 2.0 GTI 180
punk
PostPosted: Thu Apr 21, 2011 5:12 am Up
I know you have to change all the above, ECU,BSI, and key chip, im not sure theyv done this all from the same car
im going to go see them later, i havnt had a chance yet, just a phone call
Page 5 of 7
