Online Now [545]:
Visitors: 544
Today: 125235
Total: 154934117
Forums › The Car › Request a how-to › Changing airbag clock spool.An
devildriverxii
PostPosted: Tue Apr 12, 2011 3:50 am Reply with quote Up
Any ideas?
I know how to remove the steering wheel, I just need to know how to go about changing my broken spool.
Cheers.
2002 1.6 5dr Black Edition.
iainlovatt
PostPosted: Tue Apr 12, 2011 3:58 am Reply with quote Up
what do you mean by broken spool? got a pic?
(My Garage)
PostPosted: Tue Apr 12, 2011 4:04 am Reply with quote Up
It's a wire from the horn/airbag.
Remove the steering wheel by turning it 1/4 and looking behind it, there will be a hole on each side.
2002 onwards the airbag is clipped on and you poke a screwdriver in and give it a wiggle.
Earlier airbags are bolted on. Can't remember what size bolts are though.
devildriverxii
PostPosted: Tue Apr 12, 2011 4:22 am Reply with quote Up
Right, so.
As I removed my steering wheel before, this snapped off.
So I've had to buy a whole new loom, one of these.
and just wondered how I go about changing it
iainlovatt
PostPosted: Tue Apr 12, 2011 5:10 am Reply with quote Up
I did one of these few years ago,
go into the wiring near the fuse box under the steering wheel, unplug the two connection's undo the two bolts and it then pull slowly upwards pulling the cables through the centre part of the steering rack. Smile
(My Garage)
iainlovatt
PostPosted: Tue Apr 12, 2011 5:12 am Reply with quote Up
mine looked like this
(My Garage)
devildriverxii
PostPosted: Tue Apr 12, 2011 12:22 pm Reply with quote Up
Those two are different...right?
devildriverxii
PostPosted: Wed Apr 13, 2011 5:43 am Reply with quote Up
Well, after reading your post, I had no idea what you were going on about.
But once I got the fuse box cover off I knew exactly what you meant.
Cheers for this now I have my horn back my car should now pass it's MOT...in November Laughing
  Quick Reply
Username:
Message:
Quote the last message
