Online Now [235]:
Visitors: 233
Bots: 2
Today: 13868
Total: 155732650
Forums › The Car › 206 Problems › New stereo - Now center console screen doesent light?!?
Tom206
PostPosted: Tue Apr 12, 2011 12:22 pm Up
Bit confused here... got a new stereo the other day and its been a pain to work because of all this multiplexed wiring... so now it turns on and off with the ignition as i hooked it up to the ignition live ciggy ligher wire. But it wont save any radio presets ect and also the top screen(ppt40) doesn't light? i can see there's the date, time ect on there but the its really dim and the bulbs dont work?
Any ideas?
2002 2.0 HDi SP
www.facebook.com/tomwebb01
sonicscrewdriver
PostPosted: Tue Apr 12, 2011 12:53 pm Up
on the back of the stereo there's a red and yellow plug......connect the live power to the yellow connection, that should sort out the memory probably, buuuuuuuuuuuuuuuuuut the probably with the top screen in baffeling....perhaps you blew a fuse of pulled the connection loose or as theyre prone to go, its donkey dead......
206gti breaking
long time since being on here last! what happened?! lol
Tom206
PostPosted: Tue Apr 12, 2011 12:55 pm Up
But if i connect it to a constant live it wont ever turn off? :S
2002 2.0 HDi SP
heyziq
PostPosted: Tue Apr 12, 2011 1:03 pm Up
www.206info.co.uk/Foru...t=30.html, did u follow the diy tutorial? if not check back your wiring mate
heyziq.com
rypod206
PostPosted: Tue Apr 12, 2011 1:43 pm Up
it'll turn off after 2 mins, mine does it on my 180,
206 gti 180
rypod206
PostPosted: Tue Apr 12, 2011 1:45 pm Up
sorry swap the two lives round, then when you take key out its still on, thats ok because its timed, dont ask why because i dont know,
206 gti 180
Bassline_Toad
PostPosted: Tue Apr 12, 2011 1:57 pm Up
I dont think it's a fuse problem, they stated it was on, but very dim. Which is a common problem.
Try gently pushing the screen surround. Do they come on brighter? If so, all you need to do is take off the panel and twist the bulbs back into place. Simple.
Danny.
PostPosted: Tue Apr 12, 2011 4:30 pm Up
If your cars Pre Plexed. (Round tube type radio stalk)
www.206info.co.uk/Foru...16054.html
This will fix it.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
