Posted: Wed Apr 13, 2011 5:14 am |
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Wed Apr 13, 2011 5:19 am |
You can buy the correct bulb from the net and it just connects into the ballast. What bulb type is it you need?
Posted: Wed Apr 13, 2011 5:24 am |
Im confusing myself I think. Sorry Mike.
I can get the HID bulbs for the dipped beam all working and everything.
But for the full beam, the outter optic, I cannot!
The connection currently is the H4 bulb as above.
But I need a connection type for a H1 bulb..
Posted: Wed Apr 13, 2011 5:29 am |
I think I understand what you mean. Does your HID not look like this?
That is an H1 HID. The bulb is hardwired to the wiring.
Posted: Wed Apr 13, 2011 5:41 am |
Posted: Wed Apr 13, 2011 5:43 am |
Are you trying to plug an HID on to a normal bulb? How come you're putting HIDs on full beam anyways? Would you not be better off with halogens?
Posted: Wed Apr 13, 2011 6:07 am |
No.
In the middle optic (dipped beam), I'm putting HID bulbs into the lens. - which is all fine and wired up.
In the outtter optic (full beam), I'm putting normal halogens in.
But with the connectors I have, the connection type is for the H4 bulb, but I need it to work with a H1 bulb
Posted: Wed Apr 13, 2011 6:11 am |
Ohhhhhhh. All makes sense now. Yeah, I'm pretty sure you can get adaptors. Or you could try and get hold of a H1 connector, chop off the H4 one and rewire?
Posted: Wed Apr 13, 2011 6:19 am |
ahha, sorry for the long winded process Mike, appropriate the help thou.
Where could I get one? I need to actually buy it from a shop, as I need it ASAP
Posted: Wed Apr 13, 2011 7:02 am |
That's a good question...I really don't know what shop would sell an adaptor like what you're after. Would an auto electrical shop have anything like that?
Posted: Wed Apr 13, 2011 7:27 am |
What you could do is:
Find out which wire is positive and negative, chop off the end,
connect spade connects on each, positive one to fit the H1 bulb, and there should be something similar to the connector on the actual unit, connect the negative on that, then try!
Posted: Wed Apr 13, 2011 7:40 am |
smiddies wrote: |
connect spade connects on each, positive one to fit the H1 bulb, and there should be something similar to the connector on the actual unit, connect the negative on that, then try! |
Sounds like a plan!
Anyone think this won't work?
It sounds like it'll work pefectly to me..
Posted: Wed Apr 13, 2011 10:09 am |
hang on, dont you have 2 wires coming from your fullbeam optic anyway?
could match them up to the 2 from the block?
if not, then i guess you can connect one wire straight to the bulb (+ve?) and the other to the connection bit next to where the bulb goes in. It might already have a wire hanging from it. Its the metal part that sticks up about 2cm from the bulb.
Posted: Fri Apr 15, 2011 11:06 am |
smiddies wrote: |
It worked!!! Thanks man
