Online Now [215]:
Visitors: 213
Bots: 2
Today: 13956
Total: 155732738
Forums › The Car › 206 Problems › 1st gear problem
1st gear problem
karimali831
PostPosted: Thu Apr 14, 2011 5:53 am Up
i recently spent £80 on a new gear linkage as my other one was wrecked, I do not understand why sometimes I can put it into 1st gear easily and other times it is stiff... this only happens with 1st gear. it's a brand new linkage and I'm already having problems, surely I'm doing something wrong otherwise I want refund >.<
to be honest I get this problem 50% of the time which is just soo strange as sometimes it slides in easily how it should and sometimes stiff that you need to apply more pressure until it "crunches" in gear ??
206 GTI 180
PostPosted: Thu Apr 14, 2011 5:54 am Up
Sort your clutch issue out first Wink
Antknee
PostPosted: Thu Apr 14, 2011 6:01 am Up
Will it not go in when you are moving or from standstill? Its normal for it to not go in if you're moving
PostPosted: Thu Apr 14, 2011 6:05 am Up
The OP needs to sort there clutch issue out first before worrying about the gearbox & linkage Wink
206info.co.uk/Forums/v...28835.html
Antknee
PostPosted: Thu Apr 14, 2011 6:11 am Up
ahhh i didnt see that one Laughing my post is still true though i suppose Razz
karimali831
PostPosted: Thu Apr 14, 2011 6:27 am Up
if I'm going up hill in slow traffic and need to change gear 2 to 1 why not? im confused what you mean lol.
206 GTI 180
PostPosted: Thu Apr 14, 2011 6:33 am Up
Try Blipping the throttle.
Norvvv
PostPosted: Thu Apr 14, 2011 6:35 am Up
I get this sometimes, tends to be at the start of the day. Just double clutch a few times then it should be fine. But yeah as they said, sort clutch Smile
2001 1.4lx
PrePlexed 5 door.
Northeast206
PostPosted: Sun Apr 17, 2011 5:20 pm Up
typical 206 a think their all the same mines sometimes hard to get into first and my friends was aswell nothing to worry about
kit325
PostPosted: Tue Apr 19, 2011 6:24 am Up
I have similar problem as well, very difficult to get into 1st gear. After cahnging the gear oil, is all alright and changing gear is more smooth now.
kit
