Online Now [285]:
Visitors: 284
Today: 121585
Total: 154679239
Forums › The Car › 206 Problems › suspension or backbox??
Go to page Previous  1, 2
kingdom200
PostPosted: Thu Apr 14, 2011 10:48 am Up
i think the real question is.....how big are the people in the back lol??
i know lower cars with lower exhaust that dont scrape..... saying that take everyones advise as the exhaust looks a lot lower than the norm
PUG1OFF Cat Cams/ ECU project
karimali831
PostPosted: Thu Apr 14, 2011 10:56 am Up
it is either one fat ass or two normal weighted people.
I can confirm when no one is in the car, the pipe is 22cm away from the ground.
206 GTI 180
karimali831
PostPosted: Thu Apr 14, 2011 11:01 am Up
macca1411 wrote:
karimali831 wrote:
just want to know why the one I chosen was not recommended?
Have you ever stood at the side of the road waiting for the big beefy car you heard 20 minutes ago to go past, only to find it is a Corsa crawling along, being driven by a baseball capped, spotty teenager, led almost horizontal, with foot to the floor in second gear just to make all the noise?
If you had a performance engine, then i'd say go for it.
At the end of the day it's your money so buy whatever you want. It's not my cup of tea.
no you got me wrong I'm not looking for performance just my feelings I want to get a new one because my current one is all rusty and falling apart.
206 GTI 180
AX-Rated
PostPosted: Thu Apr 14, 2011 11:07 am Up
Sounds as if the middle section is hitting the torsion bar when your tackling bumps.
Although exhaust manufacturer put an upward bend to go around the torsion bar/rear axle part, a lowered exhaust would do this.
Black 03 GTi
PostPosted: Thu Apr 14, 2011 1:13 pm Up
I wasn't saying you will get any performance from it, just loads of noise.
TBH you would find it cheaper buying a standard backbox and fitting it yourself (only 1 clamp) and if you still want to make it look different, buy a stainless exhaust tip.
Jamie1337
PostPosted: Thu Apr 14, 2011 3:18 pm Up
Trade Rating: +37
Why don't you stop over the top of the bump and make sure nothing's touch it? Tbh I'd expect it's more of something banging/knocking than scraping, which you'd notice differently.
Light Right Foot FTW!
PostPosted: Fri Apr 15, 2011 1:22 am Up
From the 2 pictures you have put up, on the first one there doesn't appear to be any scrape marks on your back box. Are the humps that you are hearing the noise on the little blips in the road, or the full width ones?
On the second picture, looking at the condition of the suspension mountings, I would be more drawn to thinking the noise was coming from there. While the car is parked up, rock the car from side to side on the suspension, you may hear the noise.
Also, this might sound daft, but check to make sure your wheel brace is secure in the boot. It is easy for the clips that hold it in place to break, might even be worth checking the spare wheel carrier is tight while you're there.
Page 2 of 2
