Posted: Wed Apr 13, 2011 6:49 pm |
Right, bought some XSI alloys for my 1.4 LX earlier. Went to fit them tonight, and they seem rather snug to get on. the bolt holes line up as they should. Just the centre caps dont quite fit on like the stealies did. Got them on in the end. However tightened the bolts up went for a quick drive and checked them again, they tightened up again. Went for a longer drive and they stayed tightish but I still got a bit more turn on them. I used the bolts that came with the stealies, do i need some different ones? Anybody else done this? Will the fit properly?
Posted: Wed Apr 13, 2011 11:23 pm |
You need alloy bolts I think! Something like mcguard locking nuts
| You never really learn to swear until you learn to drive | |
Posted: Thu Apr 14, 2011 2:04 am |
Posted: Thu Apr 14, 2011 3:40 am |
LeeThr wrote: |
I used the bolts that came with the stealies, do i need some different ones? |
You MUST not use steel wheel bolts on alloy wheels!
Get the correct alloy wheels bolts fitted ASAP / stop driving the car / put the steel wheels back on till you have the correct alloy bolts for the alloy wheels!
Posted: Thu Apr 14, 2011 4:08 am |
MrBSI wrote: |
LeeThr wrote: |
Get the correct alloy wheels bolts fitted ASAP / stop driving the car / put the steel wheels back on till you have the correct alloy bolts for the alloy wheels! |
The stealies will be back on as soon as i get back to them.
Posted: Thu Apr 14, 2011 5:43 pm |
Right, quick update, back on the stealies for now. The fronts where okish, seemed a bit snug on the centre caps but came off with very little force needed. However the rears where very snug. Had to give them a good quick from behind to get them off. Does anybody know whats up? Anybody else done put XSI alloys on a 1.4 LX? How snug where they or wernt they?
Posted: Thu Apr 14, 2011 6:01 pm |
can put any alloys of any 206 onto any other 206, just make sure you have the right bolts
have a read through here and the other threads in that section, will help you out 206info.co.uk/Forums/v...17495.html
Posted: Thu Apr 14, 2011 6:08 pm |
I know in theory they should fit. They did seem to-ish. Just like I said where the centre caps sit was a lot more snug than the stealies, the stealies with a tiny bit of effort you can move them around a bit if the stud holes dont quite line up. However the alloys once there sat on the centre caps will not budge watsoever.
Posted: Fri Apr 15, 2011 12:47 am |
They may have been snug but the steel bolts could of worked there way out or even snapped, better to be safe than sorry
Posted: Fri Apr 15, 2011 10:33 am |
ukskater01 wrote: |
They may have been snug but the steel bolts could of worked there way out or even snapped, better to be safe than sorry |
I know that, the alloys are now sat in the garage untill I get the correct bolts. I just want to know why the centre caps on the alloys where the meet the hubs are so snug. Are they all like this?
Posted: Fri Apr 15, 2011 11:15 am |
Oh sorry! I'm afraid I'm not sure as I haven't taken my alloys off yet, I'm sure someone else will be able to answer this
cheers
Posted: Fri Apr 15, 2011 11:17 am |
probably just a slightly smaller centre bore on the alloys
Posted: Fri Apr 15, 2011 11:19 am |
no, they should be quite tight fit
Posted: Fri Apr 15, 2011 11:20 am |
Seabook wrote: |
no, they should be quite tight fit |
As in that tight they wont even spin on the centre caps?
Posted: Fri Apr 15, 2011 11:22 am |
LeeThr wrote: |
Seabook wrote: |
As in that tight they wont even spin on the centre caps? |
not without resistance
