Online Now [348]:
Visitors: 347
Today: 69111
Total: 156305658
Forums › The Car › 206 Problems › Suspension 'clunk'
Suspension 'clunk'
MutilateTheDead
PostPosted: Fri Apr 15, 2011 12:33 pm Up
Hey guys, couple of things ... First off, when going around left corners (and only left corners) and over rough roads I get a slight vibrate through the whole car and steering wheel as if something is loose, maybe a wheel bearing? Not sure if the fact it only does it around left corners helps with finding the problem? Secondly ... When i first start my car and pull off the drive i get a clunking sound (guessing it's from the suspension?) this happened when i first got the car lowered but stopped for about 2 months and now is back, any ideas? Cheers in advance Smile
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
cosmicdance
PostPosted: Fri Apr 15, 2011 1:43 pm Up
Sounds to me like the ball joint is worn on one side of the car.
Mine did that previously Where it made a noise when I set off and also vibrated through the steering wheel over rough roads.
Andy
Andy
macj
PostPosted: Fri Apr 15, 2011 1:47 pm Up
Check anti roll bar drop links
SDK206
PostPosted: Fri Apr 15, 2011 1:48 pm Up
possibly a CV joint has gone and has been for a while by what you say.
another possibility could be a seized strut top bearing but usually you would hear these more on turning when stationary like going on full lock to the left. wouldn't normally expect a vibration from most suspension parts even when knackered, so a good check underneath required!!
If in doubt, drop a cog and put your foot down Smile
PostPosted: Fri Apr 15, 2011 2:20 pm Up
i agree,
check the balljoint too
MutilateTheDead
PostPosted: Fri Apr 15, 2011 3:43 pm Up
NorthantsBen wrote:
i agree,
Just had both driveshafts replaced though?! Ball joints will be checked tomorow Smile
