Posted: Mon Apr 18, 2011 2:19 pm |
Also, you were removing 10A's.. Note:
"15A........Right dipped beam."
Posted: Mon Apr 18, 2011 2:28 pm |
Just wondering what is the likelyhood I have a flat battery
Posted: Mon Apr 18, 2011 2:29 pm |
wobblycat wrote: |
Just wondering what is the likelyhood I have a flat battery |
Does it turn over when you go to start?
Posted: Mon Apr 18, 2011 2:32 pm |
Yes but then everything goes dead
Posted: Mon Apr 18, 2011 2:35 pm |
wobblycat wrote: |
Yes but then everything goes dead |
Charge the battery up overnight then & try again in the morning
Fingers crossed you aint damaged the BSI unit.
Posted: Mon Apr 18, 2011 5:12 pm |
I charged the battery and now everything is working fine!! Thanks very much for your help, I will have an attempt at the dipped headlight tommorow, but will disconnect the battery this time ;), thanks again
