Posted: Tue Apr 19, 2011 6:28 am |
tomd0801754 wrote: |
Have you physically removed every fuse?
I really never expected a thread like this from you mate! |
Neither did I...
I'v multi metered them all from the top terminals using continuity test. Only the interior light fuse is blown but that shouldn't stop the car from starting. When I did the BSI reset and put the sidelights on, they didn't actually turn on!? Ahhhh f*** I'm just hoping I'v missing something flaming obvious..
Posted: Tue Apr 19, 2011 6:33 am |
Eco Mode displays even will a full battery, it does it if you leave the door open for too long and sometimes if you leave something turned on that could drain the battery basically to save your battery from going flat.
My car does this all the time when I'm sat in it at shows with the door open, it turns the interior light off and displays eco mode..
Have you checked, and double checked and checked every fuse again? Sometimes they're blown but don't look it, have you got a fuse tester at hand?!
The fuse you may have blown will be #4 inside the car under the steering wheel, which is a 20A fuse for the boot light, auto and steering wheel controls ect.
Also check fuse #7 in the engine compartment, and Fuse's #8 & #15 are linked to the ECU AFAIK so check them too.
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Have you actually replaced the fuse? Do that then try again
There was someone a while ago who had exatly the same problem because they installed an aftermarket HU but when they changed it back to standard it worked.
Weird but worth a try,
Posted: Tue Apr 19, 2011 6:34 am |
Ash wrote: |
Neither did I...
I'v multi metered them all from the top terminals using continuity test. Only the interior light fuse is blown but that shouldn't stop the car from starting. When I did the BSI reset and put the sidelights on, they didn't actually turn on!? Ahhhh f*** I'm just hoping I'v missing something flaming obvious.. |
Remove each fuse and test them from the legs, top terminals can give a false reading if they're connected to the car still as it can loop the system
| The Cars:
Posted: Tue Apr 19, 2011 6:41 am |
Ste206 wrote: |
Also check fuse #7 in the engine compartment, and Fuse's #8 & #15 are linked to the ECU AFAIK so check them too. |
Okay Ste, will do. I'll pull them all out if needs be... It turns over... but it's either not sparking or not injecting fuel... I think it's the second one though.
Posted: Tue Apr 19, 2011 6:46 am |
Is that not down to the immobiliser then?
Posted: Tue Apr 19, 2011 6:47 am |
Is that not down to the immobiliser then? |
Well yeh, that's what I'm thinking as the car locks with the key but not the remote (button)?
Posted: Tue Apr 19, 2011 6:57 am |
Is the fuel pump priming?
| The Cars:
Posted: Tue Apr 19, 2011 6:59 am |
Ste206 wrote: |
Is the fuel pump priming? |
I can't remember it doing so... Wait, I'll go connect the battery and try and start it... I left it for a bit.
Posted: Tue Apr 19, 2011 7:00 am |
Ash wrote: |
Ste206 wrote: |
I can't remember it doing so... Wait, I'll go connect the battery and try and start it... I left it for a bit. |
Alright well engine box fuse #15 is also for the Ignition coil and injectors, but if the fuel pump doesnt prime its something more as thats a different fuse location (#2 IIRC)
| The Cars:
Posted: Tue Apr 19, 2011 7:14 am |
Ste206 wrote: |
Ash wrote: |
Ste206 wrote: |
Alright well engine box fuse #15 is also for the Ignition coil and injectors, but if the fuel pump doesnt prime its something more as thats a different fuse location (#2 IIRC) |
It's bad.
Okay... Re-connect the battery the way you're spose to..
I turn the sidelights on and nothing happens.
Wait a bit, then put the key in.
The sidelights then come on... The pump DOES prime. Try to start the car and nothing. (I'm getting scared I'm flooding the cylinders now).
If you turn the sidelights off with the key in, they stay on. Pull the key out and the sidelights go off.
It's f****d isn't it..
Posted: Tue Apr 19, 2011 7:15 am |
Ash wrote: |
Ste206 wrote: |
Ash wrote: |
Ste206 wrote: |
It's bad.
It's f****d isn't it.. |
Posted: Tue Apr 19, 2011 7:53 am |
I dont like the sound of the last 2 paragraphs o.O
Have you pulled EVERY fuse out, checked over the two legs with a tester and put them back where they're from?
Testing over the contacts at the top sometimes gives false readings, thats the only hope I can think of for it been a simple fix, hopefully there's something more that could be checked that I'm not thinking about / know of.
| The Cars:
Posted: Tue Apr 19, 2011 8:08 am |
Ermmm i was going to laugh at you
Buts its over
New BSi, ECU and key
| Team Impossible Possible
Posted: Tue Apr 19, 2011 8:10 am |
Never mind peoples, he has fixed it
The fuse stopped the car from starting
