Online Now [386]:
Visitors: 385
Today: 93732
Total: 157283042
Forums › The Car › 206 Talk › 206 cd player query
206 cd player query
Forum Index › 206 Talk
Adazrambo
PostPosted: Wed Apr 20, 2011 8:50 am Up
seems to only play when engine is turned off :s any ideas? i might just use an fm tuner from now on tbh anyone know of anyones that wont get in the way?
206 hdi turbo
MrrNoName
PostPosted: Wed Apr 20, 2011 8:52 am Up
check that the radio is getting both perm and ignition power feeds. (red and yellow wires iirc)
Adazrambo
PostPosted: Wed Apr 20, 2011 9:10 am Up
yes all plugged in
206 hdi turbo
PostPosted: Wed Apr 20, 2011 9:20 am Up
Adazrambo wrote:
yes all plugged in
Original factory radio or aftermarket?
Year of 206?
We need more info if you want helpful replies Wink
MrrNoName
PostPosted: Wed Apr 20, 2011 9:34 am Up
lol yeh all plugged in.. but have you tested to check that they are providing power?
im guessing its the factory stock radio as you havnt said otherwise, as MrBSI said we need more info tho.
Adazrambo
PostPosted: Wed Apr 20, 2011 9:53 am Up
51 plate , stock radio, managed to get it playing once while driving.. looks like its going to read the disc but dosent and spits it out. fine if engine off
206 hdi turbo
PostPosted: Wed Apr 20, 2011 9:54 am Up
You tried using a lens cleaning disc? ? ?
Maybe when you are driving a dirty lens just cant read the disc correctly.
kurosagi01
PostPosted: Wed Apr 20, 2011 10:05 am Up
Also are you trying play your music as a audio CD or as a data type CD as used in most after market CD audio players.
Adazrambo
PostPosted: Thu Apr 21, 2011 4:06 am Up
audio CD, will try a cleaner seems to work on legitimate cd's but copies only work sometimes so its not a problem with the formatting, probably the lens - p**sing me off!
206 hdi turbo
PostPosted: Thu Apr 21, 2011 4:08 am Up
The stereo needs two live feeds for it to function you need to find the correct wires with a multi meter and see if the feeds are still there when the engine is running.
Or can you listen to the radio whilst driving? if so ignore what I just said.
Adazrambo
PostPosted: Thu Apr 21, 2011 4:29 am Up
yeah radio is fine
206 hdi turbo
PostPosted: Thu Apr 21, 2011 4:33 am Up
Try other CDs or just get a new HU they are so cheap they aren't even worth fixing.
MrrNoName
PostPosted: Fri Apr 22, 2011 5:01 am Up
your initial post made me believe that the radio wouldnt turn on when driving.. if it will turn on but not play CD's then the lens is damaged, its not worth getting it repaired, get another stock one from scrappy or ebay or an after market one. it struggles more with copies because they are made differently and more difficult to read.
PostPosted: Fri Apr 22, 2011 5:03 am Up
Its worth trying a cd lens cleaning disc Wink
