Latest: S2cgm
Overall: 17178
Online Now [78]:
Visitors: 77
Today: 35520
Total: 136507137
Forums › The Car › 206 Talk › 180 abs/esp help
180 abs/esp help
Andy180
PostPosted: Wed Apr 20, 2011 12:12 pm Up
Basically my abs and esp was playing up over the xmas period the usually abs and esp lights flashing then in january the red stop light started to flash and i lost all abs function, ive replaced both abs rings as they were cracked which didnt solve the problem i then discovered the idiot who last worked on my car hadn't hooked the abs sensor up correctly and it had been rubbing on the driveshaft and frayed right through the wire, so i went and got another sensor which got rid of the red stop light and the esp light but the abs light remained on .
I had the gar plugged in and diagnosed today and it came up with abs speed sensor open circuit low voltage and another low voltage fault i had these cleared but they came straight back on when i drove the car, has anybody got any ideas as to what i should do to cure this problem. sorry for the essay but its really starting to annoy me now lol .
GTI 180
PostPosted: Wed Apr 20, 2011 12:28 pm Up
Hansnt blown a fuse or something daft like that? ? ?
I know the ABS & ESP are the same unit but I wonder if the systems are fused individually?
Andy180
PostPosted: Wed Apr 20, 2011 12:35 pm Up
Worth a try are all the fuses for the abs under the bonnet or are there some in the car ?
GTI 180
PostPosted: Wed Apr 20, 2011 12:37 pm Up
www.206info.co.uk/Foru...=fuse.html
Andy180
PostPosted: Wed Apr 20, 2011 12:44 pm Up
thanks mr bsi bit of a silly question but where abouts are the maxi fuse bm 34s located ?
GTI 180
PostPosted: Wed Apr 20, 2011 12:46 pm Up
The BM34 fuse box is under the bonnet next to the battery
I take it you know about working on a multiplexed Pug & what not to do with the battery connected? ? ?
Andy180
PostPosted: Wed Apr 20, 2011 12:49 pm Up
i no not to work with the battery connected and ive seen the guide on how to shut the bsi down correctly.
GTI 180
Andy180+
PostPosted: Wed Apr 20, 2011 12:51 pm Up
my money would be on a sensor, best getting it onto pps to read live data to see what sensors are doing. just had to put one on mine with very simular issues
PostPosted: Wed Apr 20, 2011 12:54 pm Up
Thumb Up
mattymj
PostPosted: Wed Apr 20, 2011 2:39 pm Up
I had this fault and had to replace a wheel sensor, was making the abs cut in at strange times, i think each sensor on each wheel controls speed, abs, esp, arb and probably more.
I good diagnostic machine will pinpoint the exact sensor.
Andy180
PostPosted: Wed Apr 20, 2011 3:53 pm Up
would a faulty sensor make the abs pack up all together though ?
GTI 180
mattymj
PostPosted: Wed Apr 20, 2011 3:57 pm Up
If the lights are on the dash and the centre consol announces a problem then i guess the system can shut down!!!
Andy180
PostPosted: Wed Apr 20, 2011 3:59 pm Up
Hmmm suppose it could i hope its not a sensor as ive already replaced one
GTI 180
mattymj
PostPosted: Wed Apr 20, 2011 4:03 pm Up
Three more to do then hehe, think i got mine for about £20!!!
Andy180
PostPosted: Thu Apr 21, 2011 1:44 pm Up
It wasn't a blown fuse its looking like it could be 1 or both of the rear sensors, are there abs rings on the rear or is that just the front ?
GTI 180
