Posted: Fri Apr 22, 2011 4:21 am |
I had this light come up. Im sure when i started the car earlier i heard a loud pop or it might have been one of the baloons outside halfords popping in the sun.
When reversing i can smell a slight fuel smell. The car doesnt seem to be using any more petrol than usual.
P0402 - Exhaust Gas Recirculation Flow (EGR) Excessive Detected
Posted: Fri Apr 22, 2011 4:23 am |
Year of 206 & engine size / type?
Might be worth checking the EGR valves pipework & wiring is ok before throwing a new one on.
Posted: Fri Apr 22, 2011 4:27 am |
its a 1.1 2003, i didnt think petrol had EGR ??
Before this the car had a few issues with a misfire and had an injector replaced.
There was also an issue whree the cam belt when it changed it had about 5 nothces missing off of it however it was replaced and started fine and has been driving fine for about 3 months.
Posted: Fri Apr 22, 2011 4:37 am |
my1st206 wrote: |
Both petrol & diesel 206's have EGR valves fitted
Posted: Fri Apr 22, 2011 5:17 am |
my1st206 wrote: |
There was also an issue whree the cam belt when it changed it had about 5 nothces missing off of it however it was replaced and started fine and has been driving fine for about 3 months. |
get the timing checked, wrong timing could cause unburn fuel to be expelled through the exhaust..
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Fri Apr 22, 2011 10:04 am |
Ok guys will give mech a call will give you an update when I find out more. The cam belt was only done a few months ago and I watched him do it he used the holes on both side of the engine and put pins in them. He also asked me to hold a screwdriver in one of them on the passenger side while he turned a pulley. Then the screwdriver dropped a bit as if it lined something up. Does this sound right ?
Posted: Thu Jun 30, 2011 7:20 pm |
Its definatly the EGR valve.
Any ideas on how to clean this out on a 1.1 ??
I don't even know where it is.
Posted: Fri Jul 08, 2011 12:52 pm |
I have since found this thread (http://www.206info.co.uk/Forums/viewtopic/t=33102/highlight=p0402.html).
1, Could my cat be knackered.
I do a lot of motorway driving and do use the full range of revs. not someone to change gear everywhere at 2,000 rves.
2, I can hear a slight blowing from the exhaust from under the drivers side when opening the door and reving it a bit. but only very slightly when pulling off. Could this be the cause?
3, Could it be the EGR needs cleaning, if so how do i do this? Anyone have a photo to highlight where it is on a 1.1?
Posted: Sat Jul 09, 2011 6:20 am |
Bump ?
Posted: Tue Feb 21, 2012 1:53 pm |
Bump, Any ideas on where this EGR valve is as I have now cleared this code 4 times and its still coming up
Posted: Tue Feb 21, 2012 5:33 pm |
Looked in my Haynes Manual but it's only '98 - '01 and pre EGR for the petrol engine.
Posted: Wed Feb 22, 2012 1:10 pm |
Just rescanned and now all that appears is p0420.
