Online Now [1213]:
Visitors: 1212
Today: 159216
Total: 155250571
Forums › The Car › Solved 206 Problems › Unplugging the VVT - SOLVED
Forum Index › Solved 206 Problems
EuroPeugeot
PostPosted: Fri Apr 22, 2011 6:08 am Up
I've got the infamous VVT problem on my 180. I want to try unplugging it and giving it a clean.
Having problems unplugging it thou! It's such a tight space to get my hand in. Any tips?
iainlovatt
PostPosted: Fri Apr 22, 2011 6:10 am Up
girlfriend! they tend to have smaller hands! Smile
(My Garage)
kieron
PostPosted: Fri Apr 22, 2011 6:37 am Up
Can you not get the plug of the solenoid? or the solenoid out the head?
Account suspended
EuroPeugeot
PostPosted: Fri Apr 22, 2011 8:25 am Up
Can't get the plug out the solenoid
Ali_H
PostPosted: Fri Apr 22, 2011 9:07 am Up
You have to give it a bloody good pull mate but it will come off.
kurtis wrote:
EuroPeugeot
PostPosted: Fri Apr 22, 2011 9:20 am Up
Just literally pull it hard yeah?
Ali_H
PostPosted: Fri Apr 22, 2011 12:47 pm Up
Yup.
kurtis wrote:
Schumi
PostPosted: Fri Apr 22, 2011 2:07 pm Up
That selenoid have a stronger oring. You have to use same brutal force for remove them. Smile
2005 206 RC RED
EuroPeugeot
PostPosted: Sat Apr 23, 2011 6:42 am Up
Thanks for the replies, literally just got it out.
Getting the plug out and off the solenoid was annoying, quite hard to get to, especially with a strut brace! I took the coilpack out in the end to allow a little more room.
Getting the actual solenoid out of the engine block was even harder, very tight space so you cant really grab it properly, but it came out in the end Smile
I'll let you know if it fixes my VVT problem later after a drive Smile
data
PostPosted: Sat Apr 23, 2011 7:48 am Up
Did your EML light illuminate to warn you about the VVT solenoid being dodgy or was the car just sluggish to drive? I'm just wondering 'because my 180 seems slower some days...
Are you planning on replacing it altogether?
Onyx Black 2005 206 GTi 180, 44K miles, FSH, standard (apart from a K&N panel air filter, Angel Eyes and groovey rear & groovey front holy discs!)
Schumi
PostPosted: Sat Apr 23, 2011 8:08 am Up
VVT problem dont apper on EML light. ECU cant detect any fault about VVT without shortcut.
2005 206 RC RED
EuroPeugeot
PostPosted: Sat Apr 23, 2011 9:26 am Up
I've had the car about 5 months, and the EML has been on the whole time, but I've only recently got it read.
I've driven the car for about an hour, and there isn't a different in performance and the light hasn't gone off Sad
This was my code reading faults and I haven't fixed the air con wiring problem, so that why most likely Wink
I'm gonna have to replace the VVT solenoid arn't I? Sad
PostPosted: Sat Apr 23, 2011 10:00 am Up
Yuk, nasty s**te Snap On scanner Twisted Evil
EuroPeugeot
PostPosted: Sat Apr 23, 2011 12:23 pm Up
Updated the title as solved, as the original question/post has been solved Wink
But the VVT problem and the air con problem has not been fixed Sad
data
PostPosted: Sat Apr 23, 2011 1:53 pm Up
Thanks - but what do you mean about "shortcut?" I maybe a bit thick and certainly an Idiot but I have a code reader and nothing is showing at the moment, so how would I find out if my VVT solenoid is sticking or stuck?
