Latest: Flyin180
Overall: 17116
Online Now [21]:
Visitors: 20
Today: 1677
Total: 95032249
Forums › The Car › 206 Problems › Suspension :S
Suspension :S
tiago90
PostPosted: Fri Apr 22, 2011 9:59 am Up
So my car started to make a lot of noise, when turning during the week.
After some checks, I had to replace the lower suspension arm today.
When the guy was fitting it, he saw something wrong with the spring. so decided to remove it to have a look.
He took the top mount off the the shock absorber and when he open it, it felt in pieces, all rusty -.-
So new top mounts needed. Saw for about £50ish on euro car parts. It should be the right price ? not overpriced right ?
Also need to replace the shock absorbers and the springs, so what do you guys recommended ? Going to take this opportunity to lower it aswell.
I have a 1.4 hdi from 2002.
would something like this do the job ? Very Happy
www.europerformance.co...=555572858
PostPosted: Fri Apr 22, 2011 10:22 am Up
Price for topmounts is about right...
Springs and shocks.. Thats expensive, well I think it is anyway..
tiago90
PostPosted: Fri Apr 22, 2011 10:40 am Up
What do you recommend tom ? want to lower it 30/40mm aswell Smile
Whirly
PostPosted: Fri Apr 22, 2011 12:18 pm Up
Alot of people recommend the following if you have a reasonable budget
www.kamracing.co.uk/pe...a-kit.html
www.europerformance.co...category=1
Either those or you could get a set of coilovers if you want to adjust the height of your car more than once.
1.4 black 206 LX, Y reg
