Online Now [2801]:
Visitors: 2801
Today: 535546
Total: 153370343
Forums › The Car › Request a how-to › how to change rear shocks
drew
PostPosted: Fri Apr 22, 2011 2:11 pm Reply with quote Up
managed to get my hands on some jamex uprated shocks for only 40 quid, which I was quite chuffed about
could do with a little help with switching them over, do I just jack the rear up and undo the bolts and switch them over, will I have to have both sides jacked up simultaneously?
PostPosted: Fri Apr 22, 2011 2:18 pm Reply with quote Up
nope, you can do it one by one.
jack up one side and change the damper, when it's done do another side.
2 bolts and nuts per damper, make sure you don't over tighten it.
drew
PostPosted: Fri Apr 22, 2011 2:28 pm Reply with quote Up
thank you,
so I just jack it up in the standard place asif I were changing a wheel
does that mean I'll have to support the axle to take the weight off it to get it off, dya think I'd be able to do that manually ie. is it heavy?
Black 1.4 lx, you can only tell when it's moving....
Uz
PostPosted: Fri Apr 22, 2011 2:31 pm Reply with quote Up
Jack the car up, take the wheel off and then take a small jack and jack the trailing arm, placing the jack under the drum, up to make taking the damper off alot easier. once jacked up just pop the damper out and just fit the new one in in reverse to how you've taken it out.
PostPosted: Fri Apr 22, 2011 2:47 pm Reply with quote Up
might be a bit hard to put the damper back as normally you will have to compress it a bit; so it depends on how hard it the damper.
mine was a d*** to do
drew
PostPosted: Fri Apr 22, 2011 2:54 pm Reply with quote Up
ahh yeah I follow, so if I jack it up more/less once I've taken the original dampner off so it lines up with the new dampner?
PostPosted: Fri Apr 22, 2011 3:33 pm Reply with quote Up
Ill be doing mine on mondat so ill take pics and make a how to
smiddies
PostPosted: Fri Apr 22, 2011 3:43 pm Reply with quote Up
You should buy new locking nuts from peugeot though, otherwise they will fall off!!
PostPosted: Fri Apr 22, 2011 4:08 pm Reply with quote Up
BOOM
[IMG]
tamz
PostPosted: Tue Mar 13, 2012 9:04 am Reply with quote Up
what size are the bolts as i will be doing my at the weekend , just so i know i have the right tools
tamz
PostPosted: Tue Mar 13, 2012 2:02 pm Reply with quote Up
anyone Smile
PostPosted: Tue Mar 13, 2012 2:32 pm Reply with quote Up
Just measure the nuts and bolts you already have on the car.
tamz
PostPosted: Tue Mar 13, 2012 3:40 pm Reply with quote Up
i was just tryin to save the hastel of jacking the car twice as the car is slammed and a nightmare to get under lol
  Quick Reply
Username:
Message:
Quote the last message
