Online Now [568]:
Visitors: 567
Today: 175142
Total: 157641967
Forums › The Car › Request a how-to › Permenant live
Permenant live
jonnym92
PostPosted: Sat Apr 23, 2011 4:20 am Reply with quote Up
I have just fitted a new CD player in my quicksilver however it only works when the ignition is on and every time it is powered up everything i changed on the cd last time (bass, treble etc) is forgotton. How would i go about running a cable so that it works without having to turn the car on and so that the radio setting and stuff are remembered.
Note: i have tried swapping the red and yellow cables but no success hence the forum
Jonny
Abzynthe
PostPosted: Sat Apr 23, 2011 4:28 am Reply with quote Up
East Area Rep - Abzynthe
did you try without swapping the red and yellow cabels?
Dillon
PostPosted: Sat Apr 23, 2011 4:30 am Reply with quote Up
Staff - Dillon
Lee wrote:
Q) My head unit is losing its memory?
A) The Red and Yellow wires supply the Headunit with the following:
Constant low level power (yellow) - this is direct from battery and stays live even when your car is off, it allows your headunit to have enough power to keep its memory settings
Ignition feed (red) - When the car is running, the headunit is supplied with more power from ignition to power it for general use.
With many h/u, these two wires dont come set up the right way round for the 206, so your h/u will run off low level power when on, and may cut out when the volume is turned up (as it doesnt have enough power going to it). Also, as the memory feed is coming from ignition, when the car stops running, this feed stops too, and the headunit loses its memory settings. Switching these two wires around fixes the problem. Many new headunits come with connectors that allows you to easily change the wires around.
This is why that red wire is used but both red and yellow needs fuses and needs connecting to h/u
Q) My head unit won't turn on/off with ignition?
A) If your car is Multiplexed.
To elaborate the head unit will 'wake up' and 'shutdown' along side the BSI (Bulti-in system interface).
Therefore when unlocking the car the HU will turn on / display time etc as the unlocking wakes up the BSI to unlock the doors etc and when the BSI shuts off after 3 minutes the headunit will also follow suit. The shutdown of the BSI will be 3 minutes after activating the central locking / alarm / closing drivers door when getting out and locking it.
This doesn't affect a Pre-Plexed 206.
Taken from here www.206info.co.uk/Foru...art=0.html
PostPosted: Sat Apr 23, 2011 4:36 am Reply with quote Up
Have you checked the output from the cables with a multimeter?
jonnym92
PostPosted: Sat Apr 23, 2011 4:39 am Reply with quote Up
yeah i have tried both ways but nothing happens. i have had a multimeter on the wires when the car is off and no power is reaching anything at all so i was wondering if i could just run a wire in from somewhere to give it constant power because when you park up its a bit of an inconvenience to keep the car running while playing music
Jonny
Jamie1337
PostPosted: Sat Apr 23, 2011 4:42 am Reply with quote Up
Trade Rating: +37
I took a perm live off my hazard switch, worked a treat.
Light Right Foot FTW!
BigDave
PostPosted: Sat May 07, 2011 7:38 am Reply with quote Up
Hello Everyone,
I have the same problem both the switched live, (red)
and the supposedly permanent live (Blue on my car)
They are only live with the ignition on.
Anyone know why this is, and how to correct it other than picking up another live wire.
As I would rather correct the fault if it is a fault.
thanks
Brand new to forums - and 206's
PostPosted: Sat May 07, 2011 7:41 am Reply with quote Up
Tried the fuse? Wink
There should be a fuse in the board, that you take out or put in half
Its a 15 amp, there is a how to on here somewhere
PostPosted: Sat May 07, 2011 7:42 am Reply with quote Up
Only works on NON plexed 206's Wink
Norvvv
PostPosted: Sat May 07, 2011 7:46 am Reply with quote Up
Which fuse is that? Mine is non plexed Razz
2001 1.4lx
PrePlexed 5 door.
PostPosted: Sat May 07, 2011 7:47 am Reply with quote Up
22 off the top of my head
Maybe 20
dumdum0910
PostPosted: Sat May 07, 2011 7:49 am Reply with quote Up
as above you can get perm live off the hazard switch or the clock .
PostPosted: Sat May 07, 2011 7:50 am Reply with quote Up
Or just wire it in correctly / use the Peugeot ISO adaptor so you dont have to bodge Wink
BigDave
PostPosted: Sat May 07, 2011 7:51 am Reply with quote Up
Mine is a 2001Y non plexed
I haven't checked the fuses as i presumed that it wouldn't go live with the ignition switched on if the fuse had blown.
MrBSI do you mean non plexed cars do not have apermanent live
smiddies
PostPosted: Sat May 07, 2011 7:52 am Reply with quote Up
Or put both Ignition and Pernermant wire down the Red wire, Thats what Ive done!
  Quick Reply
Username:
Message:
Quote the last message
