Online Now [450]:
Visitors: 449
Today: 182692
Total: 154561933
Forums › The Car › 206 Problems › car dying..
car dying..
Liam-HuTcH
PostPosted: Sun Apr 24, 2011 6:31 am Up
East Area Rep - Liam-HuTcH
problem started a few weeks ago. The car when stopping at traffic lights for instance would just lose power and die. Once this has happened it takes up to ten minutes before it will let you start it again. Once it does start it shoots out tones of black smoke and sounds like its missfireing. Parts that have been changed is a full service. Map sensor and coil pack none have solved the problem. It managed to work correctly for a few days after above have been changed. Today on the way to the shop it died twice so ended up just coming home. Box suggestions or anyone in the area that could come have a gander?
Team: Smashed Up Firedance
Team: Black 206
DanPug206
PostPosted: Sun Apr 24, 2011 8:57 am Up
My car also loses power at a stop sometimes, 1 time it done it every corner i went around on the way to work which is less than a mile away, once i got to work, i phoned rac up, they came out and told them about it and he told me it was the idle control sensor/valve, he cleaned it and it works okay now, get the occasional issue, but advised me to get a new one. just haven't got round to getting one.Seems similar to mine, might not be the same issue tho.
my car sometimes idles at above 2,000 too.
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
Liam-HuTcH
PostPosted: Sun Apr 24, 2011 9:25 am Up
i have a new idle control value fitted to my car. It also sometimes idles at 2.000 rpm. And sometimes decideds to shoot to 5000 and stays there.
Team: Black 206
PostPosted: Sun Apr 24, 2011 9:28 am Up
Who fitted the idle control valve?
Havent lost the O ring seal when you removed the old one?
DanPug206
PostPosted: Sun Apr 24, 2011 10:00 am Up
Sounds the Same as me, peugeot wanted £120 or something for a new one
08 Seat Ibiza Sport
Liam-HuTcH
PostPosted: Sun Apr 24, 2011 10:47 am Up
i fitted the idle control value. And it had all the oring attachede
Team: Black 206
leigh_boy
PostPosted: Sun Apr 24, 2011 1:48 pm Up
check plugs, might be coil pack i had simliar problem , or can be the green plug coolent temp sesnor
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
mattievrs
PostPosted: Sun Apr 24, 2011 4:48 pm Up
sounds like an overfuelling issue to me and i would start at the coolant temp sensor. The car hasnt done that many miles has it? Have you thrashed the b******s off it to give it a good clear out?Low miles on an older car smacks of it being coked up aswell.
NO LONGER ACTIVE ON THE FORUM
Danny.
PostPosted: Fri May 06, 2011 5:35 pm Up
Changed the coil pack.. And spark plugs for Bosch
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
