Latest: flipflap
Overall: 17140
Online Now [293]:
Visitors: 292
Today: 90842
Total: 113890680
Forums › The Car › 206 Problems › Two issues
Two issues
danhodson
PostPosted: Tue Apr 19, 2011 10:27 am Up
Hey guys I've developed two issues recently with my Pug, its a 206 Roland Garros with the digital aircon, I've noticed at night none of the lights on the aircon dash light up, however the display still does. Is it a fuse issue or is there one bulb that lights all the buttons?
The second issue is today I noticed my Rev counter has stopped working, I've used the search function, but there is no conclusive answer about how to troubleshoot.
Can anyone help?
elcamino
PostPosted: Tue Apr 19, 2011 10:49 am Up
If other dash lights are ok could be the bulbs behind the display or bad plug connection.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Tue Apr 19, 2011 11:34 am Up
Climate control unit is gonna be the backlight bulbs, there might be a How To on the forum somewhere but anyway the bulbs are pretty easy to replace.
Rev counter is either the needle has come loose on the cluster OR there is an internal electrical fault with the cluster.
danhodson
PostPosted: Tue Apr 26, 2011 2:18 am Up
The rev counter has intermitantly come back to life, though it was inaccurate as it was 1000 rpm to high.
Can some one point me in the right direction in the engine bay as to where the sensor plug is?
PostPosted: Tue Apr 26, 2011 2:20 am Up
Rev cointer is controled by the engine ecu.
danhodson
PostPosted: Tue Apr 26, 2011 2:30 am Up
Oh, so there is no way I can fix it?
PostPosted: Tue Apr 26, 2011 2:35 am Up
Being a non plexed 206 the fault is most likely with the instrument cluster itself.
BBA repair stuff like this & it will come with a warranty
www.bba-reman.com/uk/index.aspx
Have you popped the clear plastic front of the cluster to check the plastic needle of the rev counter hasnt come loose from the metal shaft?
mattievrs
PostPosted: Tue Apr 26, 2011 2:36 am Up
as already stated, try looking at the needle to see if its loose.
NO LONGER ACTIVE ON THE FORUM
danhodson
PostPosted: Tue Apr 26, 2011 5:17 am Up
I'll have a look at that to see if that's the issue. I've just purchased some bulbs so I can address the climate control issue.
danhodson
PostPosted: Tue Apr 26, 2011 10:21 am Up
I've had the clocks out this afternoon, it seems the dial is playing up as its still getting information from the ECU.
PostPosted: Tue Apr 26, 2011 4:23 pm Up
Ring BBA reman in my link above & ask there opinion if its fixable.
