Latest: heikkisj
Overall: 17126
Online Now [115]:
Visitors: 114
Today: 22778
Total: 100259062
Project sleeper
Go to page Previous  1, 2, 3 ... 41, 42, 43 ... 84, 85, 86  Next
PostPosted: Sun Apr 17, 2011 1:55 am Up
I'll ask Jenvey for exactly what I need.
Anyway, fitted the Samco hoses yesterday with the new thermostat housing that DP Engineering made with the built in temp sensor boss. A new thermostat was fitted too. Looks much smarter so now I just need to wire in the connector. I've already calibrated the new sensor and ECU together. New coolant reservoir and heater hose will arrive on Wednesday.
I also decided while access was easier to remove the noise insulation from the bulkhead. Looks a bit cleaner now and it was never going to cut out much noise from this car anyway!
Lecktorious
PostPosted: Sun Apr 17, 2011 6:35 am Up
Trade Rating: +59
Looks awesome Paul! Without a shadow of doubt, one of the cleanest and well specced 206's out there!
'98 Nile Blue 306 GTi 6
PostPosted: Wed Apr 20, 2011 2:35 pm Up
Got the rest of the new parts today. Got a new heater hose that leads to the coolant reservoir. I also ordered a new reservoir but the one that arrived was a slight different design to the old one so the new hose wouldn't fit it. So I got the £48 back that I paid for the reservoir. I'll re-use the original.
So put it all back together and I thought it best to not use any coolant just in case there were any leaks and it needed stripping down again...good job I did...
I didn't even get to start the engine.
The thermostat housing that DP Engineering modified actually leaks. They said the welding can distort it but they'd skim the housing to make sure it's flat. Well if they skimmed it they didn't do it very well because it leaks and that's fitted with a new gasket too.
The weld is also porous!
So question is do I send it back to DP Engineering to get fixed or do I just get it fixed locally? I'm not going to be putting Radweld into the coolant system to fix it!
So it's all stripped down again.
TRIS
PostPosted: Wed Apr 20, 2011 5:51 pm Up
I would personally get it fixed locally to save hassle/time with postage etc. But contact them with pictures and demand some sort of part refund.?
P*ss poor really.
From reading your whole thread, two of the biggest names in the peugeot modifiying scene have produced poor quality of goods/workmanship. DOH!!!
:0
Seb
PostPosted: Thu Apr 21, 2011 3:49 am Up
Staff - Seb
That's probably because it just got too complex for them Very Happy
PostPosted: Wed Apr 27, 2011 12:16 pm Up
Decided against sending stuff back to DP Engineering because I wanted the car together this weekend.
So I took it to a local engineering shop. So that's another £30!
To skim the thermostat housing they first had to machine the front face to make sure it would sit flat.
Why didn't DP Engineering do this when they said they would?
They also fixed the leaky weld!
macj
PostPosted: Wed Apr 27, 2011 12:37 pm Up
Because they were not paying attention..... seems just lately that if you give people jobs they see as simple they tend not to pay proper attention to detail.
I have found this a lot recently... point in case, the S/C bracket.... seems simple but has not yet resulted in one I would put my name too because they cant get the maths right and the pullies dont line up properly.... so they go in the bin Shocked
Lecktorious
PostPosted: Wed Apr 27, 2011 12:41 pm Up
Trade Rating: +59
Question is Paul...will it be ready in time for a few sunny days?
PostPosted: Wed Apr 27, 2011 12:52 pm Up
I think it just goes to show how many cowboys are in the industry. None of the work I've had done is rocket science but it's the simple things that have let it down. As Macj says it's the attention to detail that's lacking and as the saying goes - the devil is in the detail.
It will be back together this weekend. I might tax it at the beginning of May but then again I might spend the money on a proper throttle linkage instead. I'd like to get the cooling fan wired to the Omex before it goes anywhere.
So who understands relay wiring? Is the Omex fan output below a +ve or a -ve?
macj
PostPosted: Wed Apr 27, 2011 1:03 pm Up
As I understand it. The ECU uses an earth return policy. You supply the live 12v to the relay and the ECU will earth it to turn it on. As with everything Paul. Double check with them first.
PostPosted: Wed Apr 27, 2011 1:05 pm Up
I'm going to email Omex tomorrow. The Omex ECU triggers the earth for everything else so I'll see what it does for the fan control!
Seb
PostPosted: Wed Apr 27, 2011 1:15 pm Up
Staff - Seb
From that diagram you supply a 12V live into the relay and it gets earthed.
EDIT: I'm not sure what else you mean however, the fan is evidently earthed, as the upside down triangular lines mean an earthing point, however you are talking about the Omex output? Where is it leading to?
As I understand it, most are lives, if they are not lives, they are earthed.
PostPosted: Wed Apr 27, 2011 2:30 pm Up
The Omex output goes to the relay. When the Omex triggers the relay it switches the high current feed to the fan.
I'm thinking, for now, of keeping the standard relays and using the Omex to trigger them (or one of them) rather than fit a new relay in the gloebox.
Bigbenj_08
PostPosted: Sun May 01, 2011 4:33 am Up
I've just read this whole thread front to back and while I don't understand the majority of the technical stuff being talked about, its a cracking read.
Glad you kept the car going after all the problems/disappointment after the original conversion. Sounds like you've spent a whole lot of cash!
Anyways, your 206 is a beast! Very Happy
Aegean Blue 1.6 16v Sport
no_offences
PostPosted: Sun May 01, 2011 4:35 am Up
very tidy engine bay
Signature removed due to size
Page 42 of 86
