Online Now [681]:
Visitors: 679
Members: 1
Today: 117201
Total: 154501488
Forums › The Car › 206 Problems › do shocks have to settle in?
Go to page 1, 2, 3  Next
PostPosted: Wed Apr 27, 2011 3:36 pm Up
Just installed some new shocks, took my car out for a drive and there's like a knocking noise from the rear, im guessing it may be the shocks but unsure
Thanks for any help
PostPosted: Wed Apr 27, 2011 3:38 pm Up
Everything done back up properly?
kencogurl
PostPosted: Wed Apr 27, 2011 3:40 pm Up
Wales Area Rep - kencogurl
its cause u fitted them ryan, everything will now fall off when your waiting at lights, Laughing
PostPosted: Wed Apr 27, 2011 3:42 pm Up
What you mean by that?
Basically i did the reverse of taking off so yeah done properly
mattievrs
PostPosted: Wed Apr 27, 2011 3:44 pm Up
They shouldnt knock mate. Id guess something is either loose after refitting or there is another problem thats been made worse by the new shocks.
NO LONGER ACTIVE ON THE FORUM
PostPosted: Wed Apr 27, 2011 3:46 pm Up
Cant think what it could.be then
But can shocks make a noise until theu sette in?
Uz said his make a noise aswell
PostPosted: Wed Apr 27, 2011 3:49 pm Up
mine don't
what dampers are they?
is there any knocking before?
PostPosted: Wed Apr 27, 2011 3:50 pm Up
Only time I have had shocks make a noise is if there bottoming out or there faulty Wink
mattievrs
Ive never heard of shocks knocking till they settle in mate. Ive know springs settle in and drop slightly but not shocks.
Id definately get the nuts/bolts checked for tightness, and the only other thing that comes to mind is that there is a worn bush or a knackered beam really.
meady
PostPosted: Wed Apr 27, 2011 4:07 pm Up
Trade Rating: +45
is it only when you go over bumps, kind of sounds like you going over loose drain covers ???
TEAM - I HATE FACEBOOK Smile
PostPosted: Wed Apr 27, 2011 4:13 pm Up
Yeah just like that but also on flat
Dont think i did the nuts very tight, just tight so you cant loosen by hand
meady
PostPosted: Wed Apr 27, 2011 4:15 pm Up
Trade Rating: +45
right is it the rarb that is inside the rear suspension or something like tht ???
PostPosted: Wed Apr 27, 2011 4:16 pm Up
did you not got a torque wrench?
better check the nuts again.
Well when i push down on the boot it makes same noise
meady
PostPosted: Wed Apr 27, 2011 4:22 pm Up
Trade Rating: +45
im pretty sure that the rear anti roll bar is inside the rear suspension and if it is then that needs tightning. This is what happend to mine when i got it lowerd. Tightend them up and it was fine Smile
Page 1 of 3
