Latest: Mr-Koekwaus
Overall: 17125
Online Now [396]:
Visitors: 395
Today: 69485
Total: 99494959
Forums › The Car › 206 Problems › Gti 180 engine problems
bigtony85
PostPosted: Thu Apr 28, 2011 1:42 pm Up
hay guys need some info. im having slight problems with my "03" reg gti 180 engine. what it is when the engine is idling the engine is shaking and slightly hunting. like its slightly miss firing. also when driving it feels like the power dissapears for a second. no engine management light on comes on every now and then with anti pollution fault (typical 206 lol) but the fault happens when the light is off.
Some one help please.
drive fast !!! live life faster !!!
qwert
PostPosted: Thu Apr 28, 2011 1:56 pm Up
a '03 plate isnt a gti 180
brum brum
Surfer333
PostPosted: Thu Apr 28, 2011 1:59 pm Up
It might be the control Idle Valve sensor - A bit of a guess. My old 306 XSI (Previous car) had problem, car when idling was shaky, also on a change down with gears say...from 3rd itno 2nd the car would cut out. Nothing would show up on the diagnostic either. Until by process of eliminantion, turned out to be the Idle Control Valve / Stepper Motor.
But it could be other factors: dirty fuel, clogged / dirty fuel line, poor injectors, or injector system i.e....the carb.
View user's profile Visit poster's website AIM Address MSN Messenger
NICKST
PostPosted: Thu Apr 28, 2011 2:06 pm Up
Mine has the shakes a bit when cold I have spent hundreds replacing all the sensors/filter/coilpack/tb. To find out a few months ago it was the realise bearing in the clutch.
My advise dont wast money like I did take it to a garage.
bigtony85
PostPosted: Thu Apr 28, 2011 2:10 pm Up
also i forgot to mention when i release the accelerator pedal it makes a burbleing noise from the exhaust like its over fueling and the fuel is burning in the exhaust. and if i change down gears harshly from high revs it backfires. injectors????
and qwert get your facts correct please.
NICKST
PostPosted: Thu Apr 28, 2011 2:14 pm Up
www.pistonheads.com/sa...765740.htm
NICKST
PostPosted: Thu Apr 28, 2011 2:15 pm Up
If there is a faulty lamba sensor it could be fueling wrong.
bigtony85
PostPosted: Thu Apr 28, 2011 2:17 pm Up
yeh nick another idea i came up with too
Big_Rich180
PostPosted: Thu Apr 28, 2011 2:36 pm Up
Muppet Rolling Eyes
bigtony85
PostPosted: Thu Apr 28, 2011 3:40 pm Up
anyone else come up with a explanation on my fault??
PostPosted: Thu Apr 28, 2011 3:47 pm Up
Get the fault codes read
perry081064
PostPosted: Thu Apr 28, 2011 3:55 pm Up
i got lee to code read my lads 307.
cleared old faults , started car , fualt appeared.
same symtoms as yours, ours was the coilpack.
...but easier to diagnose once it was read.
new coilpack fitted and job was a good un.
206 2.0 HDI
bigtony85
PostPosted: Fri Apr 29, 2011 12:50 am Up
there are no fault codes in the ecu
NICKST
PostPosted: Fri Apr 29, 2011 1:02 am Up
Things you can do with out costing money
Clean the map sensor.
Clean the tb.
Remove clean spark plugs.
Clean electrical connectors and earthing points.
But like I said mine was the clutch relase Bering that had broke.
I spent a fortune trying to sort mine.
bigtony85
PostPosted: Fri Apr 29, 2011 1:40 am Up
tryed new spark plugs cause they where due a change anyways.
