Latest: DanDan17
Overall: 17128
Online Now [122]:
Visitors: 121
Today: 23262
Total: 100450954
Forums › The Car › 206 Talk › Revs
Revs
Norvvv
PostPosted: Fri Apr 29, 2011 2:34 am Up
My revs on startup in the morming are nearly at 11000 and after a few minutes of driving they drop to just under 9000 and the car doesn't sound as good. Normal?
2001 1.4lx
PrePlexed 5 door.
drunknmunky
PostPosted: Fri Apr 29, 2011 2:36 am Up
id be worried if they ever went to 9000 ive got a gti180 and it only hits 8000 at the very top Wink
Ash
PostPosted: Fri Apr 29, 2011 2:38 am Up
That's completely normally. Car is warming itself up... Every car in the world does this...
Edit: Every fuel injected car does this.. before the hydrogen and electric loving fools come out to play.
Norvvv
PostPosted: Fri Apr 29, 2011 2:41 am Up
I thought idle was supposed to be 9000 ... Ha.
Auto choke.
PostPosted: Fri Apr 29, 2011 3:17 am Up
850rpm
JE_180
PostPosted: Fri Apr 29, 2011 4:38 am Up
8000? Have you had your limiter raised or something?
PostPosted: Fri Apr 29, 2011 4:53 am Up
Auto choke.
No such thing on a EFI car.
PostPosted: Fri Apr 29, 2011 5:02 am Up
Edward wrote:
Auto choke.
You know what I mean though.
drunknmunky
PostPosted: Fri Apr 29, 2011 5:43 am Up
why would i have there's 8000 on the clocks at the top Wink
im unsure as to wether it goes that far i was goin off the highest reading on the clocks which is 8000 Smile
Ste
PostPosted: Fri Apr 29, 2011 6:31 am Up
Staff - Ste
They dont go upto that Wink it's just on the dials, you can have it remapped and the limit raised though. Cant remember how high they go before they hit the limiter though
The Cars:
Ste
PostPosted: Fri Apr 29, 2011 6:32 am Up
Staff - Ste
Norvvv wrote:
My revs on startup in the morming are nearly at 1100 and after a few minutes of driving they drop to just under 900 and the car doesn't sound as good. Normal?
Fixed the rev's lol
But back on topic, thats normal, when the cars cold it will idle higher, then as it warms up it will drop. When I first start mine it's just over 1000 and after abit of driving drops down to 850rpm Smile
The Cars:
drunknmunky
PostPosted: Fri Apr 29, 2011 6:35 am Up
ahhh i see Smile
Norvvv
PostPosted: Fri Apr 29, 2011 7:13 am Up
Ste206 wrote:
Fixed the rev's lol
Cheers ha.
