Latest: DanDan17
Overall: 17128
Online Now [214]:
Visitors: 213
Today: 31868
Total: 100632259
Forums › The Car › 206 Problems › Damsel in Distress!!! ECU/Electrics?!
Go to page Previous  1, 2
PostPosted: Fri Apr 29, 2011 1:45 pm Up
Anyway mine's 2001 non-mux and it's EOBD.
PostPosted: Fri Apr 29, 2011 1:48 pm Up
Yeah it does have EOBD. Tell the guy to test to see if there is power going to the port, and spray some contact cleaner on it. Be better off scanning it with a better tool like peugeot planet, multi diag, bosch kts, or a high end snap-on or sealey tool that will scan things like ABS and Airbags as well
PostPosted: Fri Apr 29, 2011 1:51 pm Up
+1
But NOT WD-40.
PostPosted: Fri Apr 29, 2011 1:52 pm Up
V9977 wrote:
+1
But NOT WD-40.
That's not contact cleaner anyway Laughing
PostPosted: Fri Apr 29, 2011 4:15 pm Up
Lee wrote:
V9977 wrote:
+1
But NOT WD-40.
Exactly. Amazing how many people think it is though.
It's OK for very high tension (high voltage) circuits but never use it on
modern electronics or regret it bitterly later-on.
hwakeford
PostPosted: Thu May 19, 2011 2:28 am Up
Hi All!
Just to give you an update! My brother finally (after two weeks!!) decided to listen to you all (and me) and check the fly wheel sensor. It's mega broken, so that's good news Smile
Next query - when we took the sensor out, it came out with a bit of metal attached to it (I haven't seen this, it's just what my brother said). I'm guessing this could be a bearing or something??
Anyways, its off to the garage next week to get the clutch and sensor done, so I'm sure they'll check the bearings and stuff then.
Thanks for your help Smile
leigh_boy
PostPosted: Thu May 19, 2011 4:46 am Up
they will change the bearing as part of a clutch kit
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
hwakeford
PostPosted: Thu May 19, 2011 4:47 am Up
Cool!
Can't wait to have it back on the road.. Its been off about 4 weeks now!
MrrNoName
PostPosted: Thu May 19, 2011 4:57 am Up
glad you got to the bottom of it Smile
hwakeford
PostPosted: Thu May 19, 2011 4:58 am Up
Thanks Smile
hwakeford
PostPosted: Fri May 27, 2011 9:07 am Up
Heard back from the garage now! The clutch kit has been replaced and the fly wheel sensor also replaced. Car is driving like a dream Smile
They found a handful of bearings rolling around, and various bits of metal which looked like they might have once been bearings too. The sensor was completely screwed.
£265 lighter and all fixed.. finally can enjoy the car for a bit Smile
Page 2 of 2
