Online Now [820]:
Visitors: 819
Today: 266088
Total: 150562493
Forums › The Car › 206 Problems › indicator/lights fault
garyd
PostPosted: Fri Apr 29, 2011 2:54 pm Up
I have a 2003 206 and when i indicate right the indicators flash twice then main beam comes on,problem doesn't occur when sidelights are on,have checked fuses,wires,bulbs,earth connections and nothing obvious wrong.I am almost certain the switch is at fault.can anybody advise on procedure for changing the stalk?
NathanG
PostPosted: Sat Apr 30, 2011 2:01 am Up
You cant change the stalk you have to change the whole unit. Its called a Comms2000. Make the search facility at the top of the page your friend. Its been covered 100's of times. Ebays the cheapest place i found to buy them depending on the spec of your car i.e. rain sensor etc.
gixxerkev
PostPosted: Sat Apr 30, 2011 3:16 am Up
I had a pretty similar problem, when the sidelights were put on the headlights came on as well and the indicators didnt work. Had the Com2000 replaced and all was fine. Cost £320 in total at the dealers, worth it tho because I didnt wanna mess with the air bag and also the horn didnt work initially because they didnt connect it properly when the air bag was re-fitted, which was rectified for free. I recommend getting a new one as can you be certain anything on e-bay will be fully "serviceable", but I spose it depends how deep your pockets are !!!
An Ex '03 1.4 GLX driver, German technology all the way now.
garyd
PostPosted: Tue May 03, 2011 11:34 am Up
cheers,sorry about the bad etiquette nathan but am new here and wanted a straight answer,none of the previous threads had exactly the same problem as mine
rangers
gixxerkev
PostPosted: Tue May 03, 2011 11:45 am Up
So what have you done to resolve the problem?
PostPosted: Tue May 03, 2011 12:16 pm Up
Take it to a Peugeot main dealer then Rolling Eyes
Its gonna want a new com2000 fitting Wink
