Latest: DanDan17
Overall: 17128
Online Now [50]:
Visitors: 49
Today: 6941
Total: 100434666
Forums › The Car › 206 Talk › Camber
Camber
europug
PostPosted: Sun May 01, 2011 2:59 am Up
I no ucant get camber on the rear of a pug but wot bout front has anyone done it n can u get camber arms??
PostPosted: Sun May 01, 2011 3:37 am Up
Top mounts
PostPosted: Sun May 01, 2011 3:56 am Up
you can get camber pivot from PS. not expensive really. but only -2 degree. work on stock top mount.
adjustable top mount still won't get you enough camber to look euro enough; depends on model 2 or 3 degree is most.
PostPosted: Sun May 01, 2011 5:38 am Up
fronts can be done be getting adjustable top mounts not sure where from but i know they exist
rear can be done by very carefuly bending the axle in a press Very Happy bit dodge but iv seen it done on a 205 track car to aid the handling
starlet
PostPosted: Sun May 01, 2011 5:40 am Up
will look stupid with front camber but none at rear
europug
PostPosted: Sun May 01, 2011 9:01 am Up
no i have seen it on a photo shop and the fronts look wicked
as mine has quite a good stance the front would suit with a bit of camber
PostPosted: Sun May 01, 2011 9:21 am Up
Peugeot Sport do negative camber front hubs. Not cheap though and far too nice to be put on anything that's just for looks.
PostPosted: Sun May 01, 2011 10:10 am Up
less than 300 euro per axle.
good bargain!
consider the adjustable top mount could cost even more.
