Posted: Mon May 02, 2011 4:18 am |
Alright people,
Was going to flush out the radiator today and fill her back up. Went to open the drain screw on the radiator and there isn't the "tap" :/
Was just going to take the bottom pipe off, but surely that's going to prevent me from bleeding it
DW10TD - RHY - 2.0HDi
Gracias
Posted: Mon May 02, 2011 4:37 am |
Completely unhelpful... However... You don't know?!!?
Posted: Mon May 02, 2011 4:40 am |
Trade Rating: +59
I think Bon did a 'how-to' Lee - think you just pull off the bottom hose and drain the radiator.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon May 02, 2011 5:04 am |
Trade Rating: +45
tomd0801754 wrote: |
:O Completely unhelpful... However... You don't know?!!? |
i was thinking exactly the same thing, if lee dont know who will
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Mon May 02, 2011 5:06 am |
meady wrote: |
i was thinking exactly the same thing, if lee dont know who will |
Summon Edward the king of clean!
Posted: Mon May 02, 2011 5:13 am |
you have to take off the bottom pipe......i had to repaire a hole in my rad friday, i thought someone nicked my tap untill i noticed it was a blank......when you refill it tho you gotta take of the dust cap on the hose going into the bulkhead to bleed it...
| 206gti breaking
long time since being on here last! what happened?! lol | |
Posted: Mon May 02, 2011 5:33 am |
Yeah I think I read in a guide somewhere on here... it mentioned to loosen the bottom hose but not remove it as it can be a PITA to get back on apparently.
Posted: Mon May 02, 2011 5:36 am |
Strange that there is no drain plug. With the drain plug it's easy to keep it all tidy and controlled then draining it but without it the only option is to remove the hose and watch 5 litre of coolant spill everywhere. Keep the reservoir cap on and it will come out slower.
Posted: Mon May 02, 2011 8:12 am |
Yeah I've seen the guide, was just wondering if there was a "trick" to emptying it without getting a face full of coolant. I'm already covered in oil, brake fluid and diesel
Posted: Mon May 02, 2011 8:32 am |
Lee wrote: |
Yeah I've seen the guide, was just wondering if there was a "trick" to emptying it without getting a face full of coolant. I'm already covered in oil, brake fluid and diesel |
Keep your mouth shut, make sure the coolant isnt to hot & have a free shower as it drains out
Try not to swallow any
Posted: Mon May 02, 2011 8:45 am |
MrBSI wrote: |
Lee wrote: |
Try not to swallow any |
It's probably never been changed so it will be rusty as hell
Posted: Mon May 02, 2011 8:48 am |
Mine doesnt have a plug either, could be non genuine maybe?
| Team Impossible Possible
Posted: Mon May 02, 2011 8:52 am |
Possibly
Looks like its never been changed tho because all the bolts and nuts are mega rusty
Posted: Mon May 02, 2011 8:55 am |
Lee wrote: |
Possibly
Looks like its never been changed tho because all the bolts and nuts are mega rusty |
Random
Maybe it was an optional extra?
Posted: Mon May 02, 2011 8:58 am |
What? save peugeot 20p?
