Latest: DanDan17
Overall: 17128
Online Now [63]:
Visitors: 62
Today: 29331
Total: 100504103
Forums › The Car › 206 Talk › Steering doesn't self centre totally?
PostPosted: Mon May 02, 2011 5:52 am Up
Does anybody ever drive another car then when they get in the 206 the steering feels a bit strange?
My GTi has always had quite heavy steering, even the wife didn't want to drive it because it felt really heavy to her.
I notice now that the steering seems a bit unwilling to completely self centre. All the other cars I drive have electric or electro hydraulic power steering whereas the 206 is just hydraulic.
Does anybody else notice this with their 206?
PostPosted: Mon May 02, 2011 5:54 am Up
it happen last time when my top mount bearing is destroyed.
PostPosted: Mon May 02, 2011 5:55 am Up
Mine has new top mounts and bearings and new wishbones too.
Bigbenj_08
PostPosted: Mon May 02, 2011 5:58 am Up
Tyre pressures ok?
I'm off out in a sec so i will test lol.
Aegean Blue 1.6 16v Sport
PostPosted: Mon May 02, 2011 6:06 am Up
Everything is ok. Tyres wear evenly too. I think it's just a characteristic of the 206.
GazRG
PostPosted: Mon May 02, 2011 6:09 am Up
Electric and electro-hydraulic systems are often criticised for having an overly self-centering action.
Perhaps it's just the transition back to normal hydraulic that needs getting used to.
'98 MGF 1.8i
Team: ex-206 owner
PostPosted: Mon May 02, 2011 6:11 am Up
You are running nimrods?
Tyre size?
Might be the pump slowly passing on its way?
Twidly
PostPosted: Mon May 02, 2011 9:27 am Up
Mine does this too & pulls to the left a fair amount. My mum's steering wheel is off centre too, another 206!
PostPosted: Mon May 02, 2011 9:30 am Up
Sure that's just not torque steering?
The GTi180 and 1.6HDi and i think later 1.4 8v (TU3A) have variable power steering, whereas the rest just have normal. Maybe thats why it does it?
Bigbenj_08
PostPosted: Mon May 02, 2011 9:48 am Up
Bigbenj_08 wrote:
Tyre pressures ok?
Mine doesn't fully.... it sort of goes central, but not all of the way. done it a few goes and seems to depend on the road angles etc etc...
Definately doesn't pull the steering completely back to centre though.
PostPosted: Mon May 02, 2011 9:49 am Up
Ed, I feel exactly the same after driving another car. I know what you mean.
Twidly
PostPosted: Mon May 02, 2011 9:52 am Up
If it is... Does that make me cool? It does it more when I'm accelerating... Cool
PostPosted: Mon May 02, 2011 10:16 am Up
Yeah sounds like torque steering. But no, you'll never be cool Twidlestix Razz
PostPosted: Mon May 02, 2011 10:26 am Up
The w**ky 1.6 HDI uses an electric motor driven power steering pump located front left hand corner of the car Wink
PostPosted: Mon May 02, 2011 10:32 am Up
Still classed as variable PAS tho Razz Or at least thats what servicebox says on the characteristics for a 1.6hdi vin Laughing
