When I bought my V reg gti, the MFD wasn't working. I took it out to have a look at it and found that the previous owner had removed all the bulbs. So I bought some replacements and fitted them. The MFD still didn't work.
How easy should they fit in? I know it's a stupid question but they seem to be really loose or if I twist them the other way, they feel barely in.
The other thing is that I think they also removed the fuse for it, as I found a spare fuse in the ashtray. Would it have it's own fuse or am I barking up the wrong tree?
Can u see anything on mfd or its completely blank?and if its just background lights check if other lights A/C panel,ash tray light r ok ....you should put each lamp holder in its hole and turn it about 1/2 turn while youre pushing it in.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
