Latest: sparrowdclxvi
Overall: 17139
Online Now [275]:
Visitors: 274
Today: 8554
Total: 112396570
Forums › The Car › 206 Problems › Changing the gearbox oil on a 2.0 138?
Rob2859
PostPosted: Wed May 04, 2011 11:53 am Up
My dad has a 306 cab. Which if I am not mistaken has the 206 GTI engine.
He says its a "sealed for life" type gearbox. However it does have a leak and will need topping up. Any way to get in them?
PostPosted: Wed May 04, 2011 11:55 am Up
It's not a 206 GTi engine. It's the old iron block XU engine. Similar though. Gearbox will be a BE just like the 206 GTi though. Very unlikely to be a sealed for life gearbox so you can easily top it up. Do a search because this topic was covered the other day.
PostPosted: Wed May 04, 2011 12:31 pm Up
if it is the BE box then quite likely the filler hole is just behind the passenger wheel
Davels
PostPosted: Wed May 04, 2011 2:30 pm Up
www.206info.co.uk/Foru...tml#360012
Here is the link to the recent topic about changing the 138 gearbox oil
Rob2859
PostPosted: Thu May 05, 2011 2:15 am Up
cheers guys. I didn't think it was totally sealed but my dad was told it was. I will let him know and he will figure it out Very Happy
