Latest: TigerHunters
Overall: 17144
Online Now [54]:
Visitors: 53
Members: 1
Today: 37427
Total: 115868547
Forums › The Car › 206 Talk › Potential Dealer Balls up.......
Go to page Previous  1, 2
PostPosted: Thu May 05, 2011 5:28 am Up
better not use semi-syn on the FAP engine Laughing
Lecktorious
PostPosted: Thu May 05, 2011 6:13 am Up
Trade Rating: +59
5W30 fully synthetic for the DV6 Wink
'98 Nile Blue 306 GTi 6
PostPosted: Thu May 05, 2011 6:15 am Up
What He Said
robertmarcs
PostPosted: Thu May 05, 2011 7:58 am Up
omg! LOL. the correct part number for filter and washer should have been 1109AY and 31340, sounds like youve been given a 16488.
EPIC!
MrrNoName
PostPosted: Thu May 05, 2011 8:46 am Up
i know its not technically correct but when i change my oil i dont change the washer for a new one, i just use the old one if it looks in good condition, never had it leak after an oil change either Razz
ExoVyper
PostPosted: Thu May 05, 2011 9:01 am Up
anthony_839 wrote:
btw they both look the same.......
the one he got from a sensor has a special name and i cant remember it but it's a soft-ish metal with a rubber inner.
where as the sump washer is copper and if you twist it hard enough its that soft you can fold it lol
Op tbh when i worked as a mechanic as long as the washer in question sealed then you had nothing to worry about Smile
the only thing i'd check (a few days/a week down the line) is that it remains tight as that washer isn't as soft as the copper one
PostPosted: Thu May 05, 2011 9:02 am Up
There is nothing wrong with the washer you where sold, it will do the job perfectly well.
PostPosted: Thu May 05, 2011 10:40 am Up
Squeaker wrote:
only way to replace it is to empty the oil out again. Surely i'm not expected to drain it out and put it back in?
No need to even spill a drop. Wait until the oil is cold and slowly unscrew the drain plug. As it comes out quickly put your thumb over the hole and then pop the new plug and washer in.
MrrNoName
PostPosted: Thu May 05, 2011 10:45 am Up
edwards right, that would be the best way to do it, wait untill the oil is really thick and it will be messy but you would only loose a minimal amount if you are really set on changing it Smile
p.s ive just noticed that the "latest forum posts" bar stars out the work Balls haha
PostPosted: Thu May 05, 2011 10:46 am Up
there's nothing wrong with the washer the dealer supplied, there is no need to change it.
PostPosted: Thu May 05, 2011 10:48 am Up
I think Vauxhall use a similar plug washer.
VW use them as well.
PostPosted: Thu May 05, 2011 10:51 am Up
Aahhh, that's probably why I have one in my tool cabinet. Probably from my Jetta.
PostPosted: Thu May 05, 2011 1:58 pm Up
Mines been that washer for the past 4 services. Never leaked once.
Personally think its better, as the rubber is tight around the threads. Basically acting like a o-ring
doughboy5
PostPosted: Sat May 07, 2011 5:22 am Up
i am happy i have seen this as i didnt change mine on a service i did the other day and was just thinking maybe i should have. lol
206 GTi
Page 2 of 2
