Latest: eltel666
Overall: 17146
Online Now [105]:
Visitors: 104
Today: 7120
Total: 116144176
Forums › The Car › 206 Problems › MFD not working
MFD not working
Arthur_Daley
PostPosted: Wed May 04, 2011 4:13 am Up
When I bought my V reg gti, the MFD wasn't working. I took it out to have a look at it and found that the previous owner had removed all the bulbs. So I bought some replacements and fitted them. The MFD still didn't work.
How easy should they fit in? I know it's a stupid question but they seem to be really loose or if I twist them the other way, they feel barely in.
The other thing is that I think they also removed the fuse for it, as I found a spare fuse in the ashtray. Would it have it's own fuse or am I barking up the wrong tree?
TEAM: Diablo Red
elcamino
PostPosted: Thu May 05, 2011 2:41 pm Up
Can u see anything on mfd or its completely blank?and if its just background lights check if other lights A/C panel,ash tray light r ok ....you should put each lamp holder in its hole and turn it about 1/2 turn while youre pushing it in.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
