Online Now [366]:
Visitors: 365
Today: 109761
Total: 156216438
Forums › The Car › 206 Talk › Roof bars
Roof bars
Forum Index › 206 Talk
europug
PostPosted: Fri May 06, 2011 3:49 am Up
I have bought a set of bars gonna fit them tonight, do they cip into the door seal, i dont have to take roof runners off do i or r kits different??
PostPosted: Fri May 06, 2011 8:31 am Up
I know some of them you have to remove the black plastic strip on the roof to get at the channel that the roof bars secure to.
Small plastic rivet at each end that secure the plastic strip.
PostPosted: Fri May 06, 2011 8:33 am Up
Ruffy_206 has roof bars,
could pm see if there same/similar.
europug
PostPosted: Fri May 06, 2011 10:07 am Up
Yea will do because these bars seen long and over run those black runners because i also thought ud have to takem them off
colinn
PostPosted: Fri May 06, 2011 10:36 am Up
these, which I got from halfords, have feet that sit over the roof strips and a bit that fits under the door seal - there are indentations in the metal under the door seal that show exactly where to position the bars. I also sawed off bits from the ends of the bars because they stuck out quite a bit, being a generic kit.
europug
PostPosted: Fri May 06, 2011 3:08 pm Up
Wicked thanks for the pic, I pmed ruffy who helped me a lot also like u say there's fittings under the door seal I never knew bout lol
PostPosted: Fri May 06, 2011 3:18 pm Up
Can't see you having to remove the roof strips as they form part of the windscreen finish.
On other makes that do have the fittings below the roof strip, there is normally a slideing cover to gain access to the mounting point.
