Online Now [1164]:
Visitors: 1163
Today: 205466
Total: 155294375
Forums › The Car › 206 Problems › Help with Fault Codes
Squeaker
PostPosted: Sat May 07, 2011 11:39 am Up
Got 2 codes come up, no idea what they refer to, anyone have any ideas, where i need to be looking?
P0104 Mass or Volume Air Flow Circuit Intermittent
P0113 Intake Air Temperature Circuit High Input
drunknmunky
PostPosted: Sat May 07, 2011 11:42 am Up
what model of 206 is this on? have you fitted an induction kit or anything to change your air intake?
EDIT: you should be looking towards your air intake system as thats what these things refer to Wink
EDIT again Embarassed would be good if you could tell me if this is throwin up the anti pollution fault or not? thanks
PostPosted: Sat May 07, 2011 11:45 am Up
Check the connector on the MAF (on airbox), and make sure you've fastened the piping back up after you serviced it
This moniters the air coming into the engine, and might flick up because your MAF is knackered / not working
Squeaker
PostPosted: Sat May 07, 2011 11:58 am Up
Yes i was getting Anti Pollution fault, i'll have a look later then, i bet its something i havent reconnected, i was looking for the glow plugs yesterday, while calming down from the hub nut being a *********
Is the MAF that plug?
Edit, its the 1.6 Hdi
PostPosted: Sat May 07, 2011 12:15 pm Up
MAF is inbetween the engine and air filter
Squeaker
PostPosted: Sat May 07, 2011 12:24 pm Up
Turbo side?
Not driving back from Swansea?
PostPosted: Sun May 08, 2011 5:12 am Up
The thing after the airbox that is just outlined rather than grey, before the pipe
Squeaker
PostPosted: Sun May 08, 2011 10:35 am Up
Cheers for that, i checked it last night, the plug had minimal movement, i think it can't of been in fully, because i drove to Killamarsh, only for it to appear as soon as i started it up to come home. I unplugged and replugged it earlier, been for a drive into Donny since and it hasn't come back.
The thing in grey is that the full part you buy if its gone?
PostPosted: Sun May 08, 2011 11:15 am Up
Nah you can just buy the sensor on its own. I bought one the other month, £110 I think for a Siemens one
Squeaker
PostPosted: Sun May 08, 2011 12:45 pm Up
£110 for a sensor?
PostPosted: Sun May 08, 2011 3:04 pm Up
Part Number 1920.GV @ £126.85
Squeaker
PostPosted: Sun May 08, 2011 3:07 pm Up
Not cheap then, been for a run down A1 to get it up to temp, didnt come back, so im hoping i just didnt replace it properly the first time, only got Unblock Diesel Filter again Very Happy
Need to find a garage to fit them glow plugs...
PostPosted: Sun May 08, 2011 4:36 pm Up
Cant you do the plugs yourself?
Squeaker
PostPosted: Sun May 08, 2011 4:49 pm Up
Probably, but they are round the back under the airbox, saw 3 of them, couldn't see the 4th, i just think they will be a pain to get to, i'm probably going to drop bits, tools, anything down there at some point.
Ive also got to take it in to get the abs ring swapped, couldnt shift the hub nut with anything, need them to heat it up and then have a go with a big ass impact gun. So thought might as well get them to do that too.
Really should check the relay first, but i don't have any equipment that could check if a relay is buggered or not.... Will find out when the new plugs are in and if that code comes back.
