Latest: Puggingalong
Overall: 17129
Online Now [201]:
Visitors: 200
Today: 30241
Total: 100699607
Forums › The Car › 206 Problems › long drive ahead.
long drive ahead.
Go to page Previous  1, 2
PostPosted: Sun May 08, 2011 11:42 am Up
jedwards wrote:
MrBSI wrote:
jedwards wrote:
do you know of any good degreasers as it could still have quite a lot of oil in the system maybe?
NON bio washing up liquid / powder or dishwashing tablets.
MUST be NON bio Wink
Couple of tablets added to the expansion bottle when cold & take the car for a drive to get it nice & hot, smells lovely & also cleans all the crap out the cooling system at them same time better then stuff you can buy on the shelf.
awesome! will it need flushing afterwards?
Rise it out with water from the hose before putting all the pipes back on.
PostPosted: Sun May 08, 2011 11:54 am Up
If it's had a new radiator and thermostat, other than replacing the temp sensor I would also think it must be the water pump. Unless the head gasket was fitted incorrectly.
jedwards
PostPosted: Thu May 19, 2011 11:56 am Up
ok so ive just taken my front bumper to look at the wiring on the fan and found that 1 prong on both of the relays has corroded and snapped, wondering if you can replace these or do i need a whole fan unit? also could this be why my fan kicks in at 103degrees and not 93 like a lot of people on here are saying?
dsdasdsad
Page 2 of 2
