Posted: Wed May 11, 2011 3:10 am |
i know this sounds silly, but i loked at a few pics and i cant see that it has a washer jet on the rear like the fronts do, i have a bit of pipe sticking out of the top break light so presume its ment to be there but cant see how it comes apart so i can look at it propperly as at the min, water comes out in a staight line and not directed to the window.
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Wed May 11, 2011 3:11 am |
It comes out of the break light
Posted: Wed May 11, 2011 3:14 am |
how does the break light come off?
| *DEAD*206 Gti 138
Posted: Wed May 11, 2011 3:16 am |
Open boot and two nuts behind the light,
Posted: Wed May 11, 2011 3:18 am |
Two bolts from the inside secure it in then it needs to be popped out, when it's popped out the washer hose just pulls off it.
Having said that I found it extremely difficult to pop out and ended up snapping mine, maybe there is a special way to do it but I couldn't see anyway to get into it.
Posted: Wed May 11, 2011 3:28 am |
NorthantsBen wrote: |
Open boot and two nuts behind the light, |
nice 1 i will have a look at it later i was jsut going to pull it off
| *DEAD*206 Gti 138
Posted: Wed May 11, 2011 3:29 am |
Before you undo the nuts all the way, tap the back of the ractchet/spanner so light pops out/comes loose
Then finish unscrewing nuts
Posted: Wed May 11, 2011 3:30 am |
nice 1 cheers for the tip
| *DEAD*206 Gti 138
Do you think it's possible to modify the rear jet so it acts more like a spray instead of p**sing against wall?
Posted: Wed May 11, 2011 4:09 am |
Jay794 wrote: |
Do you think it's possible to modify the rear jet so it acts more like a spray instead of p**sing against wall? |
You'll end up mangling it like I did! Was spraying on the road out behind me when I was finished with it!
Posted: Wed May 11, 2011 4:17 am |
I hate my rear washer jet, the timing is completely wrong with the back wiper I have to leave it spraying for ages to completely cover the window
Posted: Wed May 11, 2011 5:16 am |
i think thats the same with all of them mate, timing is so out!
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Wed May 11, 2011 5:25 am |
You have to hold it down for a while before it actually does any work!!
Posted: Wed May 11, 2011 5:41 am |
All you need is a quick twist for the rear wash / wipe, the BSI takes care of the squirting
