Posted: Tue May 10, 2011 12:44 pm |
Guys,
I noticed that I can hardly see the level of the coolant in my reservoir and was wondering what the best way to clean the reservoir is.
Is it also worth changing the coolant at the same time only I've had the car about 5 years and its never been done?
I did try to find a How to on the forum but couldnt find one (nothing to say there isnt one its probs just me being bad at searching)!!!
cheers
| 206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate | |
Posted: Tue May 10, 2011 12:48 pm |
It would have been changed during a full service - tell me its been serviced properly?!
And they're normally quite a dense white colour - I doubt cleaning it would do much good.
Posted: Tue May 10, 2011 12:50 pm |
tbh mate it's not worth cleaning as its white plastic and is not opaque so you couldn't see the coolant level anyway, i got the same problem and looking to replace with a alloy tank with sight glass but nobody makes them
Posted: Tue May 10, 2011 12:56 pm |
Quarmbo wrote: |
And they're normally quite a dense white colour - I doubt cleaning it would do much good. |
It last had a proper service at 20,000 and its now on 64,000. I changed the oil, oil filter and air filter last year.
It had new brakes and discs fitted to the front wheels the other week.
I am in the process of doing what I can. I'm going to be changing the plugs and brake fluid myself soon.
Is it worth doing a coolant change then?
Posted: Tue May 10, 2011 1:00 pm |
Yes, for definite. So its done 44k miles without a proper service?! Assuming it was a full service at 20k. Crikey. Either do a full service yourself or take it somewhere and get a full service.
Posted: Tue May 10, 2011 1:04 pm |
Quarmbo wrote: |
Yes, for definite. So its done 44k miles without a proper service?! Assuming it was a full service at 20k. Crikey. Either do a full service yourself or take it somewhere and get a full service. |
Yep I'll be doing it myself
Posted: Tue May 10, 2011 1:08 pm |
Needs the cambelt doing as well
Posted: Tue May 10, 2011 1:10 pm |
Lee wrote: |
Needs the cambelt doing as well |
Yep, I might get someone to do that for me though.
Posted: Tue May 10, 2011 3:58 pm |
finners wrote: |
Guys,
Take it of & put it in the dish washer
Posted: Wed May 11, 2011 7:20 am |
In all seriousness how do people check their water level? I have a 2.0 engine with the square reservoir as the back of the engine bay. As said above it s white plastic you can't see through. I normally takes me around 10 minutes with a torch wobbling the car like made to try and spot it. There must be an easier way.
Out off all the things this is the most ridiculous thing on my car.
Posted: Wed May 11, 2011 7:23 am |
Davels wrote: |
Out off all the things this is the most ridiculous thing on my car. |
Agreed. Was a right pain when I had my 206s
Posted: Wed May 11, 2011 12:19 pm |
easiest way to check ive found is with a torch and wobble the hell out of it to see the level.....mmmm invention?
Posted: Wed May 11, 2011 5:30 pm |
mine has kind of gone a light brown but i can see it fairly well
Posted: Thu May 12, 2011 12:25 am |
I always put slightly more than the recommended amount of coolant in so when the hose is squeezed you can see the coolant level moving.
Posted: Thu May 12, 2011 12:35 am |
i have the same issue but because forge or bailey don't do anything for the 206 we're stuck with it, i sometimes feed something inside to check the level but the nozzle is a weird shape so it is difficult to get an accurate level
