Latest: dreyfalon
Overall: 17121
Online Now [71]:
Visitors: 70
Today: 14202
Total: 97295309
Forums › The Car › 206 Problems › Brake light issues??
berpsta
PostPosted: Wed May 11, 2011 9:56 am Up
hi wonder if anybody can help with a problem i have with my brake lights, both left and right ones have stopped working but the 3rd one still comes on...ive checked fuses and bulbs all seems to be good...they are standard fit light units on a 1998 206
anybody had similar issues???
thanks in advance
Sean
my other 2 cars are buses
PostPosted: Wed May 11, 2011 10:12 am Up
Check the brake light switch in the passenger footwell area. Little white plug.
Abzynthe
PostPosted: Wed May 11, 2011 10:15 am Up
East Area Rep - Abzynthe
my need to clean the connections into the light cluster? a bit of dirt could have got in it.
PostPosted: Wed May 11, 2011 10:18 am Up
Doubt that as it's on both sides at the same time with different connections.
berpsta
PostPosted: Wed May 11, 2011 10:26 am Up
cheers guys i will have a look ive had the rear lights out and can say the connections between the connector and light unit cluster look ok and the different bulb holders all look to be in the same condition (indicator and lights)....
I will check the switch in the footwell (this could well be the problem as ive had a clumsy footed passenger in recently)
thanks again
Sean
PostPosted: Wed May 11, 2011 3:44 pm Up
Aint the switch, the OP said the high level one is still working Wink
PostPosted: Wed May 11, 2011 4:24 pm Up
Must be a bulb issue, because the third brake light is powered by the n/s one
