Latest: heikkisj
Overall: 17126
Online Now [66]:
Visitors: 65
Today: 7631
Total: 100186309
Forums › The Car › 206 Problems › clunking noise
clunking noise
Northeast206
PostPosted: Fri May 13, 2011 8:08 am Up
when i set of in first gear my car makes a loud clunking noise from the drivers side on the front only makes one clunk
Northeast206
PostPosted: Fri May 13, 2011 8:14 am Up
any suggestions because i have no clue what it could be
Rob2859
PostPosted: Sat Aug 06, 2011 7:42 am Up
I think I am getting the same as you. But now it clunks when coming to a stop or sometimes when going over a bump with the brakes on. Its got louder too. Both my droplinks and wishbones are new so its ether one or both drive-shafts or the top mounts. Possibly an engine mount.
PostPosted: Sat Aug 06, 2011 7:47 am Up
Tried the ball joint?
stu_gti180
PostPosted: Sat Aug 06, 2011 9:38 am Up
check for any play on your wishbones... droplinks.. when my driveshaft was wore out it clattered when pulling away from a stand still.
Gti 180, 04, Janspeed cat-back system, viper induction.
ian89
PostPosted: Sat Aug 06, 2011 10:03 am Up
i got this when changing through gears turned out to be the bottom engine mount got a mechanic to take a look he got me to bounce the clutch pedel in 1st and he could tell by how much the engine rocked
