Latest: Andyblue64
Overall: 17123
Online Now [207]:
Visitors: 206
Today: 23766
Total: 98053169
Forums › The Car › 206 Talk › Any Ideas?
Any Ideas?
Tom206
PostPosted: Fri May 13, 2011 2:10 pm Up
Is there any way of fixing or hiding the ugly metal strip where you jack the car up?
The jack leaves bend marks in it once jacked up and it looks ugly?
2002 2.0 HDi SP
www.facebook.com/tomwebb01
Barking
PostPosted: Fri May 13, 2011 2:20 pm Up
side skirts
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Fri May 13, 2011 2:45 pm Up
i just paint my sills black with some hammerite every now and again, hides them from most angles...
although my car being slammed means you can't see them usually Smile
roberto.f
PostPosted: Fri May 13, 2011 2:59 pm Up
And to avoid them getting any worse, don't jack the car up on the sills.
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
Tom206
PostPosted: Fri May 13, 2011 8:32 pm Up
hmm might paint them black... but as my car is silver might look stupid ?
2002 2.0 HDi SP
PostPosted: Sat May 14, 2011 1:33 am Up
You didn't use a trolley jack under the sill did you?
wardie_206
PostPosted: Sat May 14, 2011 1:56 am Up
^^^^ what he said???
PostPosted: Sat May 14, 2011 3:02 am Up
I have same problem, there proper shagged, god knows what the last people did to them lol
Started rusting now, going get rid of rust, bend them straight again, hammer right them up black ( as its black Under the car, less likely to see, )
PostPosted: Sat May 14, 2011 10:55 am Up
like ben said, because they are under the car painting them black means you can't see them...
so no, it won't look stupid, my car is white and i do it
