Latest: sparrowdclxvi
Overall: 17139
Online Now [115]:
Visitors: 114
Today: 14591
Total: 113255026
Forums › The Car › 206 Problems › car too low
car too low
Boydie
PostPosted: Fri May 13, 2011 11:23 am Up
i jus got coilovers put in my car but its too low to get a trolly jack underneath! i need some1 to hold up my arch while i slide the jack in..but im dredin the day i get a flat tyre on my own..so my question im askin is that can u get a special type of jack that would b able 2 get under the sills?
Gti 180
PostPosted: Fri May 13, 2011 11:26 am Up
www.amazon.co.uk/Chock...516&sr=8-2
just drive onto blocks of wood easy... i constantly have this problem Laughing
-RAJ-
i just use the standard boot jack, then put the trolly jack under
Take a block or two of timber to drive up.
tofy92
London Area Rep - tofy92
the wind up jacks should be no problem or alternatively carry a peice of wood in ure boot and drive onto that Smile
Boydie
PostPosted: Fri May 13, 2011 11:32 am Up
even the back of my car is that low i need 2 jack up the torson bar 2 get the spare wheel out haha
Gti 180
2Oh!6
PostPosted: Fri May 13, 2011 12:02 pm Up
Yeah bricks or blocks or wood for me to. Cool
VTEC goes BWAAAAAAH! Wink
PostPosted: Fri May 13, 2011 1:11 pm Up
Good old bricks and wood Smile
I used them wind up jacks before I lowered it even more (wouldn't fit under then) but broke two of them :s they seem far too weak ,
PostPosted: Sat May 14, 2011 3:36 am Up
If you cant get under your car to get the spare wheel out
Loose some wieght
Alternativelty take a block of wood round with you
PostPosted: Sat May 14, 2011 3:51 am Up
Just got a draper scissor jack for jacking it up high enough to get a normal jack in and it goes under fine and mines nearly on the bumpstops.
You can use the jack in the spare wheel to jack it up first but it's really crap.
Rob2859
PostPosted: Sat May 14, 2011 3:55 am Up
MY standard trolley jack doesn't fit under mine but its not ever lowered :S
